S-Works SL 2018
flyingbink1
by flyingbink1
@Dareef : can you use swiss stop brake pads on them ?
rcb78
by rcb78
Yes, I'm using Black Prince pads in my EEs, they take any Shimano-style pad.
CrankAddictsRich
by CrankAddictsRich
Yup... using EE's on my Venge with DA9000. Love them. The modulation feels much smoother across the full length of the lever pull compared to the DA9000 brakes and obviously, lighter weight. I'm using Swiss Stop Black Prince Pads.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
http://www.skratchlabs.com
2015 Specialized S-Works Allez
2015 Specialized Venge Pro
2014 Specialized S-Works Shiv TT
by Nefarious86
Jagwire links?
Using Tapatalk
CrankAddictsRich
by CrankAddictsRich
Nefarious86 wrote:Jagwire links?
Yes...
Mep
by Mep
Nice looks like a pretty neat cable job, less that one stray brake cable on the right.
flyingbink1
by flyingbink1
Thanks guys , will go for the ee brakes !
by Nefarious86
So with 9100/EE Brakes, R sys SLR clincher wheels and either a 9100P or NG on 2017 Sworks crank how light are people thinking a 58cm frameset can be built up?
Using Tapatalk
CrankAddictsRich
by CrankAddictsRich
Mep wrote:Nice looks like a pretty neat cable job, less that one stray brake cable on the right.
Thanks... yes, they're all very tight. Unfortunately, that brake cable needs a little bit more slack there so that it doesn't pull when I turn the bars.
DaReef
by DaReef
Nefarious86 wrote:So with 9100/EE Brakes, R sys SLR clincher wheels and either a 9100P or NG on 2017 Sworks crank how light are people thinking a 58cm frameset can be built up?
15-16lbs - just a wag
Really light would be etap and CLX 32 tubulars
by Nefarious86
Yeah I was thinking that combo also, I prefer the feel of 9100 over eTap tbh but if the ViAS frame sells bare I'll use the etap and P2M TypeS crank off it. Already have the Mavics and at 1300g bare they are more useable than tubs with the amount of sh*t on the roads here. Under 6.1kg would make me happy without haveing to use things like a GimGum expander etc, then swap put with the 202s, CLX64s and Stinger6s as needed :)
Using Tapatalk
RyanH
by RyanH
9150 is roughly 50g lighter than eTap I believe.
Strava
by Nefarious86
If I'm going electric it will be eTap as I've already got it on the ViAS. Dont see the value in 9150 over 9100.
Using Tapatalk
raggi
by raggi
Anyone looking at getting the S-Works womens frame?
53x12
by 53x12
raggi wrote:Anyone looking at getting the S-Works womens frame?
No.
