S-Works SL 2018
LionelB
by LionelB
Can someone point me to the geometry chart. The one on the Specialized web site looks wrong. The 61cm has a STA of 76 deg... Can't be true.
CrankAddictsRich
by CrankAddictsRich
LionelB wrote:
Sun Aug 12, 2018 10:52 am
The website I'm looing at has the 61cm bikes with a 73 deg seat tube angle.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
Tpb10505
by Tpb10505
jthreec wrote:
Mon Aug 06, 2018 11:09 pm
Specialized Tarmac Pro Frameset 54cm
910g Frame (hangar, bottle cage bolts, internal cable)
357g Fork (uncut)
176g Seatpost
I just picked up a 58cm Tarmac Pro myself, haven’t weighed the fork or post, but the frame w/ hanger and bolts was 1040g.
sfo423
by sfo423
What does the 58 s-works weigh in at?
Tpb10505 wrote:
Tue Aug 14, 2018 2:32 am
357g Fork (uncut)
176g Seatpost
LionelB
by LionelB
CrankAddictsRich wrote:
Sun Aug 12, 2018 3:54 pm
OK this makes more sense.
Tpb10505
by Tpb10505
The only reference on here I could find was a 58cm Ultralight at 879g. I would imagine the SWorks would be in the mid 900’s?
sfo423 wrote:
Tue Aug 14, 2018 5:05 am
357g Fork (uncut)
176g Seatpost
morganb
by morganb
My 52 Expert (I stripped to build with eTap) was 920g with hanger, cage bolts, seat wedge, and mech cable guides.
DCcyclist
by DCcyclist
Any idea what the weight difference is like between say 56 vs 61? I am looking at the Pro Disc model. What's the Tarmac Pro Disc weight for the stock model? ty
Tpb10505
by Tpb10505
DCcyclist wrote:
Tue Aug 14, 2018 4:02 pm
You just have to search the forum a bit. In the Tarmac Disc thread someone posted a 56 Pro Disc was 17.42lbs ready to ride, or 16.4lbs without pedals/cages/Garmin mount/sensors
DCcyclist
by DCcyclist
Tpb10505 wrote:
Tue Aug 14, 2018 4:49 pm
Thanks will check!
r3m
by r3m
Anyone know this color?
hypercycler
by hypercycler
During a ride yesterday the bottom bracket started to creak, it felt like the ceramicspeed bearing is shot (I've been through many bb issues with different bikes)... just wondering if this is covered under warranty? I know Ceramicspeed is offering 4 yrs warranty for their parts, but in this case should I go after Specialized? The bike was purchased 5 mos ago from my LBS with about 1300 miles on it. Thanks.
Kevinch76
by Kevinch76
How different is S-works from normal tarmac? I believe the weight difference is quite negligble other than bragging the "S-WORKs" logo...believe the difference is minimal? Anyone can enlighten me on this..just curious... probably quality of the FACT carbon..S-works Fact 12....Tarmac pro...Fact 11?
wheelbuilder
by wheelbuilder
hypercycler wrote:
Mon Aug 20, 2018 9:19 pm
I personally think Ceramic Speed bottom brackets are not fantastic, but I work on and install them a lot. You don't need to replace it. Every CS bottom bracket comes with a tiny syringe loaded with their own grease. It's like a Chris King BB injection tool idea, but much slower, and a lot more work. Pry off the seal with the corner of a razor blade......try not to bend or warp it. Completely degrease and clean the balls and races. Let them dry, then inject the grease fully into the bearings. work it in, move the balls around, inject grease everywhere whether it fits or not. Re-install seal. It will work silently and smoothly again. Your Specialized dealer should have dozens of those syringes laying around.
rsantos450
by rsantos450
Does anyone have a picture of this bikes? Very undecidedImageImage
Sent from my Redmi Note 3 using Tapatalk
