S-Works SL 2018
ome rodriguez
by ome rodriguez
S-works tarmac ultralight size 52.
liam7020
by liam7020
That frame weight is heavier than I would have expected. My 56cm Sagan with bottle bolts and seat wedge etc was 920g. Either way enjoy your frame!
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
r3m
by r3m
New Aerofly bar come with the new venge, anyone now if it's possible to fit the bar on all the stem? Could be a good choice for the tarmac as all round bike :)
sychen
by sychen
r3m wrote:
Tue Jul 03, 2018 2:07 pm
No reason why not.. quickstep while testing had a non Specialized stem combined with the new aerofly.
Designed with standard clamp diameter and widths.
seanlsc
by seanlsc
New aerobar on venge look real nice! Would be great if it were on a SL6. Hope someone can confirm this.
surfinguru
by surfinguru
The bars are 31.8 so any stem that is also 31.8 will work. My issue is finding a pair in 42. My LBS has had it on order for over two weeks now. (Also shown as out of stock on Specialized's web page.)
Js2
by Js2
Built up a UL frameset size 54 rim brake version.
Fork is 340g uncut, 300g after cutting
Seatpost 171g
Frame weight with derailleur hanger + bottle cage bolt + rear brake internal cable routing guide is 790g.
liam7020
by liam7020
My Sagan in size 56cm with Campag Record EPS, S-Works chainset and Xentis Squad 4.2 clincher wheels. Weight as photographed is 6.37kg. More details and snaps to follow in Gallery thread.
taodemon
by taodemon
Bike shop just emailed me with frame and fork weights for my size 56.
Frame: 860 grams
Uncut fork: 350 grams
Should be built by tomorrow for the afternoon ride.
Having everything moved from my SL5 to the new SL6 frame.
Burton610
by Burton610
Are you guys 100% sure you have the Ultralight Frame sets that you are weighing?
Most of the weights are definately out from what we should be expecting and the pictures look like the logos are in white not silver.
The Ultralight frame has silver logos and the standard frame set in black has white logos.
Can you confirm which logos you have as most look white but it may just be the camera.
TobinHatesYou
by TobinHatesYou
It’s not a secret that Ultralights never came anywhere close to the advertised 733g for a 56cm.
cycleboyco
by cycleboyco
Js2 wrote:
Wed Jul 11, 2018 1:05 am
Seatpost 171g
I think this is the lightest UL I have seen on this thread-this is how mine came out of the box as far as with rear hanger, bottle cage bolts, and routing guide. Those parts are roughly 20 grams, so still at least 50 grams heavier than the 733g (which I think was supposed to be for a 56). The black/silver hologram disc frames only seem to be a few grams heavier than the rim UL.
The UL logo looks white from certain angles and with a flash since it's reflective, but the silver/gray is pretty obvious in person.
I had a finish issue with my UL frame that Specialized is replacing for me, so plan on weighing the replacement frame this weekend and will post that weight, though I do not expect it to be much different than the 815g out of the box weight of the current 56 frame. Also will be interested to see when the replacement frame was manufactured-my original frame was ordered in January 2018 and had a June or July 2017 manufacture date (decal under the top tube), so seems like my original frame would have been one of the early frames based on the original release-always thought it was curious that they were sold out for a long time, but when they became available to order again, the frame I got was from July 2017.
ome rodriguez
by ome rodriguez
ome rodriguez wrote:
Wed Jun 20, 2018 3:33 pm
Mine is definitely ultralight. Pic with camera flash below. Was disappointed by the weight, but after riding it was secondary.
taodemon
by taodemon
Final build weight with pedals and garmin mount ended up being 7.14kg (15lbs 12 oz) down from 7.51kg (16lbs 9oz) with my SL5 frame.
Some of the dropped weight was from the EE brakes vs DA9100, though some weight was probably added by going with an 11-30 ultegra cassette instead of the old 11-28. The hed wheels don't look so great with the new frame compared to the old one which might make the upgrade to a set of clx50's happen sooner than I had planned. Bike still has the old plastic cages from my original Venge which I'll swap out soon too. Eventually I think I want to try etap on it but the wheels are my next priority.
DA9000 shifters / derailleurs
Sworks Crankset w/ power2max pm, praxis 52/36 rings
ultegra chain / cassette (11-30)
EE brakes
Aerofly bar
Sworks stem
Sworks power saddle
DA9100 pedals.
HED Jet5 wheels
mbdurham17
by mbdurham17
Js2 wrote:Built up a UL frameset size 54 rim brake version.
Seatpost 171g
Well there’s consistency my 54 UL was exactly the same
