S-Works SL 2018
morganb
by morganb
Bike was 15lbs on the dot with a Zipp SL Sprint. I'm changing to Keo Blades which should put it under 15. Super happy hitting that with aluminum clinchers and a power meter.
CrankAddictsRich
by CrankAddictsRich
That's not surprising at all... as I said in an ealrier post, I was super imspressed with the weight of that frame in stock build form, considering was an ultegra mechanical build and had the stock boat achor wheels.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
idinfo68
by idinfo68
Here is my Tarmac SL6...5.36 kgs (11.8 lbs)
Who said he was heavy?
More information on www.baron-noir.com
Video : https://www.youtube.com/watch?v=-rVqSTVoGZY
poppiholla
by poppiholla
Beautiful bike. Congrats. Looks a lot like my S-works
arizonahalfnhalf
by arizonahalfnhalf
So... i'm too lazy to dig through 86 pages...
Who has experimented with craming 28+ tires in their new tarmacs??? Very curious to see if anyone has maxed out some rim/tire/brake combos.
CrankAddictsRich
by CrankAddictsRich
the fellow posting right above you has Conti 25's on his Tarmac, which surely measure upwards of 28... 28's should fit pretty easily.
morganb
by morganb
I have 25mm Pro One tubeless on Pacenti SL23 rims (20.3mm internal) which measured north of 29mm on those rims. Plenty of clearance all round. I could almost definitely fit the 28mm labeled versions with decent clearance.
mbdurham17
by mbdurham17
arizonahalfnhalf wrote:So... i'm too lazy to dig through 86 pages...
I am currently running Sworks turbo 28. I switched from 26 turbo cottons which I’ve used for the past year as I have been riding a lot of rough gravel dirt back roads around my house. The sidewalls hold up better and they feel better on those roads.
arizonahalfnhalf
by arizonahalfnhalf
morganb wrote:
Fri Jun 08, 2018 12:18 pm
Awesome! Thanks for the measurements. Super helpful. Thanks!
Tooslow69
by Tooslow69
Hi all,
Just picked up a new 18’ disc S-Works and found out I’ll need to install a EW-WU111 to get Bluetooth to work. Will this unit replace the JCW-200 directly?
Thank you
jj911c2
by jj911c2
Tooslow69 wrote:Hi all,
Thank you
Yes, I just swapped the WU111 for the junction and it worked fine.
mbdurham17
by mbdurham17
I noticed over the weekend I started to develop a creak from the bottom bracket. Has been silent until now (about 1000 Miles) anybody experience the same? If so what’s the fix?
dshiels
by dshiels
Hi all,
Quick question. I picked up my non-UL at the end of last week and on my maiden voyage on Monday evening I started to get a knocking from around the seatpost area when riding over rougher surfaces. I started after hitting a pothole on a descent so I'm guess it may be the internal DI2 battery. What way is it secured in the aero seatpost? Is therea proprietary mount?
Thanks
idinfo68
by idinfo68
dshiels wrote:
Wed Jun 20, 2018 8:33 am
.... I started after hitting a pothole on a descent so I'm guess it may be the internal DI2 battery. What way is it secured in the aero seatpost? Is there a proprietary mount?
Thanks
Yes, a proprietary mount comes with the frame. Good quality and adapted to the seatpost...
dshiels
by dshiels
idinfo68 wrote:
Wed Jun 20, 2018 12:26 pm
Thanks
Thanks. I will have to investigate to see if it is the battery/mount that has come loose
