S-Works SL 2018
guyc
by guyc
liam7020 wrote:
Thu May 24, 2018 8:37 pm
You may well be correct. I'm thinking the Assembly Paste doesn't do what it says on the tin! Something with "true grit" may be the answer.
Take the bolt out and make sure there’s no threadlock on there. Then grease it before re-assembly and use assembly paste on the post.
Threadlock can give a false torque reading. The shop that built my C64 up have seen this a few times with various makes.
sychen
by sychen
Liam I'm using tacx paste.. Seems to hold pretty well.
liam7020
by liam7020
sychen wrote:
Thu May 24, 2018 10:15 pm
Thanks for that info - I'll give it a go.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
idinfo68
by idinfo68
Just received...
Tarmac SL6 size 56 (not Ultralight version)
Weight without any frame parts : 805 grs
Fork uncut : 340 grs
Seatpost : 177 grs
Seatpost Clamp : 21 grs
Derailleur Hanger : 15 grs
Small frame parts : 15 grs
Project will be under 5.4 kgs !
alexmcm09
by alexmcm09
liam7020 wrote:
Thu May 24, 2018 2:40 pm
Anyone else have issues with their SL6 seatpost slipping? Torqued using Park Tool wrench and Morgan Blue paste applied - still f*ckin' slipping!!
What are you torquing it up to? My LBS (ex Specialized mechanic) recommended a little carbon grip paste and torque the bolt up to 8nm. Seems like a lot but the new clamp is designed to avoid crushing seat posts
liam7020
by liam7020
alexmcm09 wrote:
Fri May 25, 2018 11:07 am
I was using Morgan Blue paste which appears to be totally inadequate. Got some Tacx paste today so I'll try that and take your advice for a little more torque. Cheers.
tonytourist
by tonytourist
Are you talking about the saddle rail clamp or the actual seat post expander?
I have my seat post expander at 5.5nm with 0 issues, I have the rail clamp at 8 nm and it's fine. I think 8nm on the expander would be excessive and could cause issues.
tyro13
by tyro13
Good morning from Belgium,
about ee brakes.....is the frontbrake sl6 specific or can i use a regular dual mount ee brake as front brake? (and is just the rear brake tarmac sl6 specific)
on my bmc slr01 i run sram etap with a gxp crankset, can i use this gxp crankset on the new tarmac sl6?
thx for the support.
idinfo68
by idinfo68
tyro13 wrote:
Mon May 28, 2018 7:55 am
Yes, use normal direct mount front brake...
Yes with the good adapter for this axis, example :
https://www.c-bear.com/en/products/bott ... 0-sram-gxp
morganb
by morganb
Just a note, I ordered the Tarmac specific eeBrakes as a pair from Fairwheel and they look different than the regular eeBrakes, so here will be an aesthetic difference, but a normal direct mount will work on in the front. The other thing I noticed is they use a different spring than a normal eeBrake.
Frankie - B
by Frankie - B
liam7020 wrote:I'm a tad old school but this is one of my major Room 101 issues. Why do all these new cyclists cover their high end race bikes with these dinky little lights, saddle packs, camera mounts etc etc etc. I KNOW the lights maybe make a bit of sense but Jesus people have a litle decorum! How to emasculate a beautiful bike! Would Mario or Eddy do it? You know the answer.
Living in Holland/Europe, i’m having a bit of the sane thoughts. In general, lights aren’t needed here unless it is dark. For people living in the US or other places where road bikes on the road are less common these lights can be live savers. The make you seen on the road from further out and make the driver aware that you are ‘there’.
Saddle bags are another endless discussion. Let’s not go there.
Please follow me on Instagram
jhalmar
by jhalmar
tyro13 wrote: on my bmc slr01 i run sram etap with a gxp crankset, can i use this gxp crankset on the new tarmac sl6?
I have this Praxis Works gxp adapter and works like it should be: https://praxiscycles.com/product/conv-bb-sram-gxp-road/
tyro13
by tyro13
Thx guys for the fast response.
On the site of r2 bike i found this....
https://r2-bike.com/SRAM-Innenlager-Tru ... lized-OSBB
So for the bb there are a few options....praxis and c-bear....weight of the praxis is nog so lightweight.
jhalmar
by jhalmar
tyro13 wrote:Thx guys for the fast response.
AFAIK your link is not the correct one because of PressFit and I would choose threaded version because it basically (hopefully) is totally free of creaking and clicking. My Praxis Works GXP weighted 144g.
If you dont mind the price this might be an excellent choice: http://www.ceramicspeed.com/sport/produ ... SRAM%20GXP
morganb
by morganb
Need to wrap the bars still. Waiting for a straight post to come in and will probably switch the stem to a sprint stem.
