S-Works SL 2018
Jugi
by Jugi
liam7020 wrote:Maybe it's just the harshness of the flash but that surface looks a tad rough?!
R2-Bike has better product pics .
nulldreiundreissig
by nulldreiundreissig
Jugi wrote:
Mon Jan 21, 2019 2:11 pm
2,3g... Now i'm curoius on the weight of the original's weight... :beerchug:
Jarett
by Jarett
New member ... new build :)
Sagan Superstar LTD 56cm
Dura-Ace
CeramicSpeed
Roval
Tune
6,8kg
bruno2000
by bruno2000
I've ordered my frame with the fluo pink yellow purple color this morning and will build it with Campagnolo sureper Record 12spd.
Regarding the seatpost, does S offers a seatpost with 0° offset or can you turn the seatpost?
I've found a picture of the bike of Nikki Terpstra where the seatpost was facing forward.
cyclespeed
by cyclespeed
So my carbon downtube cover arrived. Really nice, lacquered carbon weave, just seems more 'right' than an aluminium one on a carbon bike.
I don't have my scales with me right now, but I reckon it's 2g versus 4g.
If anyone's interested, let me know.
liam7020
by liam7020
Jarett wrote:
Wed Jan 23, 2019 6:47 am
Dura-Ace
CeramicSpeed
Roval
Tune
6,8kg
That's an extremely nice build, good health to enjoy! Is that the 20mm headset cover supplied with the frame? I opted to use a FSA 15mm cover with a 5mm spacer on my Sagan SL6 but the 20mm cover looks good on yours so I might change. Is that a 100mm or 110mm SL stem you're using? Ta
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
cycleboyco
by cycleboyco
bruno2000 wrote:
Wed Jan 23, 2019 11:12 am
You cannot turn the seatpost. Zero offset posts are available in 2 different lengths (320mm and 380mm?). I don't have the part numbers, but they are someplace earlier in this massive topic. Sounds like a unique build with the color/Campy combo. :thumbup:
Jarett
by Jarett
[/quote]
[/quote]
Hi, thanks :)
Stem is 100mm and headset cap is Specialized BG Fit with conical spacer ... https://www.mcconveycycles.com/9306/pro ... p-cap.aspx
I'm 178cm and seat is 77cm to top from bottom.
nulldreiundreissig
Very cool! I can't wait to see your bike once its completed
Jarett
by Jarett
nulldreiundreissig wrote:
Wed Jan 23, 2019 8:06 pm
Specialized original seatpost with 0° offset - https://www.amaincycling.com/specialize ... 05/p744744
But ... I rode it and it is very uncomfortable :(
Beaver
by Beaver
Is there any reason to use a GXP crank instead of BB30?
https://www.bespokecycling.com/build-ga ... h-sram-red
morganb
by morganb
Beaver wrote:
Thu Jan 24, 2019 4:27 pm
If you have bad BB shell alignment then using a thread together GXP adapter could fix this and force the bearings into parallel alignment.
Guivd
by Guivd
Hi all,
also new member, but following this thread for a long time...
Switched from sl5 to sl6
"purple haze" 58cm frame
dura ace di2, ee brakes,
light bicycles 36mm rims with extralite hub front and powertap gs rear (here with veloflex master tires but normally tubeless with pro one)
6,7 kg of pure hapiness
and the original downtube di2 port cover weight:
liam7020
by liam7020
Loud and proud - like it!!
