Campagnolo UT-BB130 Ultra-Torque Cup Tool
by 5 8 5
I'm wondering what your experiences are using this tool to fit UT cups.
Mine seems quite a loose fit and it leaves marks where the splines locate. Wasn't too bothered when fitting Record cups to my winter training bike but I wanted a good finish when fitting SR cups.
I initially tried electrical tape but that just cracked so tried masking tape. Two rounds of it gives a good fit and left minimal marks. BTW I'm also holding the tool in place with a thread rod.
Valbrona
by Valbrona
Tacx make a spanner/wrench type tool with plastic inserts, but can be a little difficult to get a good amount of purchase on it.
Mockenrue
by Mockenrue
I use a piece of polythene or a plastic bag over the cup. It stops the marking and provides a more snug fit.
ColnagoEPQ
by ColnagoEPQ
I place a paper towel between the cup and the tool. No marks and a tight fit.
Attermann
by Attermann
i use the the one from icetoolz instead, i found the campagnolo one, less than satisfying, i have the same issues as you, and just think that it's poorly made.
BRM
by BRM
5 8 5
by 5 8 5
Thanks for the replies chaps.
Valbrona wrote:Tacx make a spanner/wrench type tool with plastic inserts, but can be a little difficult to get a good amount of purchase on it.
Valbrona, is there actually a UT specific tool? I know there's one for Campag square taper.
Mockenrue wrote:I use a piece of polythene or a plastic bag over the cup. It stops the marking and provides a more snug fit.
ColnagoEPQ wrote:I place a paper towel between the cup and the tool. No marks and a tight fit.
Great minds etc!
So it confirms I haven't got a duffer and the loose fit seems to be intentional.
Attermann wrote:i use the the one from icetoolz instead, i found the campagnolo one, less than satisfying, i have the same issues as you, and just think that it's poorly made.
Icetoolz have got a good rep.
The quality / function of the Campag tool does seem strange as Campag tools are if anything over engineered.
BRM wrote:For a high precision BB tool:
Look at Wolftoothcomponents, Abbey tools or Real World Cycling
http://www.wolftoothcomponents.com/collections/tools
http://www.abbeybiketools.com/collections/tools
http://www.enduroforkseals.com/id122.html
Thanks, they look like good quality tools. Obviously I've got a workaround that performs well enough but I'll save them for future reference.
jmagoulas
by jmagoulas
I just purchased the Wolftooth one and fitment is great on 70mm ITA cups.
Valbrona
by Valbrona
The Tacx is standard external BB fitment: https://tacx.com/product/bottom-bracket-cup-tool/
But you will realize that is not as expected when you get one. The plastic insert doesn't fit fully over the cup like the other wrench-type tools, but being plastic is does not mark cups.
by 5 8 5
Thanks Valbrona, I was looking at the cartridge tools.
