170mm cranks for 5ft 10.5inch rider?
pdlpsher1
by pdlpsher1
Funny thing is, I won't notice a 2.5mm change in saddle height but I do notice a 2.5mm change in crank length. I think this is because a 2.5mm change is really a 5.0mm change since the crank rotates around the axle. The crank is longer at both the 12 o'clock and 6 o'clock positions.
Go for the 170mm. You will like it.
Allen254
by Allen254
Shrike wrote:Also have a 31inch inseam. Industry standard seems to be 172.5mm, but would like to try 170mm.
http://bikedynamics.co.uk/FitGuidecranks.htm
Seems most recommendations are a bit shorter than industry standard.
Also apologies for question spam recently :P
any rider of any height can rider which ever crank length but you will have to adjust saddle height.
DaReef
by DaReef
I'm 5'11.5" and use 170mm.
Racingevo
by Racingevo
I have the same inseam and I use 170 when I upgraded my crank to Ultegra 6800. I definitely did notice a difference for the better. My cadence increased slightly but it's hard to empirically prove that. I can climb out of the saddle a lot longer with the shorter cranks and if I were to do it again I'd go for 165mm but I'm stuck for the time being since I got a stages crank arm power meter.
Bridgeman
by Bridgeman
I need more money.
mattr
by mattr
stormur wrote:Is thickness of all road shoes equal ? Or can vary even 3-4mm ? insole thickness ? Sock ? Pedal stack ?
none of which make the slightest difference to the circle to which your foot has to pass through. Crank length does.
Allen254 wrote:any rider of any height can rider which ever crank length but you will have to adjust saddle height.
they'll also need to have their knees operated on eventually.
RussellS
by RussellS
I am 5'11" tall. I use 175 cranks on my seven geared road bikes. 172.5 and 170 on my two single speed bikes. Mainly because those are the cranks I had in the spare parts box when I built the single speeds. Never notice any difference when riding geared and single speed bikes on back to back days. I can spin 90 rpm comfortably all day long on any crank length.
racingcondor
by racingcondor
I'm 5'11" (33 inseam and UK size 12 feet!) and moved to 170 cranks after riding 165's on track.
I can feel the difference but I doubt that there is a measurable performance difference. I'd imagine the only difference in reality is the reduced likelihood of pedal strike when riding through a tight corner.
RedCoke
by RedCoke
I think inseam is more impoart factor than height only.
inseam(mm) x 0.216?
Mr.Gib
by Mr.Gib
RedCoke wrote:I think inseam is more impoart factor than height only.
inseam(mm) x 0.216?
That number doesn't seem correct. A factor of 0.216 would have me on a 190 mm crank. I am 6 feet (183 cm) with average proportions. I am happy with anything up to 175 mm. I prefer 170 mm due to past knee injuries, and spinal injuries.
tinozee
by tinozee
Checkout slowtwitch forum for more comprehensive discussion on this. Short crank arm is fine. Watch out for nutty ideas like Lennard Zinn's long cranks.
joeyb1000
by joeyb1000
LloydP wrote:I'm very close to your proportions and use 170mm cranks. It works fine for me. Try it and see!
same here.
Allen254
by Allen254
:roll:
RedCoke
by RedCoke
inseam(mm) x 0.216?
It is "inseam(mm)" not height. Please check this.
http://www.stevehoggbikefitting.com/bik ... which-one/
RedCoke
by RedCoke
Also, this site would be helpful.
http://www.peterwhitecycles.com/
