Another Pedal Thread..
Wingnut
by Wingnut
I had them and Dura-Ace are pretty good in every department except one...they feel crap when clipped into imo. The float feels awful but the bearings are smooth and the pedals are super sturdy... ;)
"It's not the destination...it's the ride!"
BdaGhisallo
by BdaGhisallo
Wingnut wrote:I had them and Dura-Ace are pretty good in every department except one...they feel crap when clipped into imo. The float feels awful but the bearings are smooth and the pedals are super sturdy... ;)
As much as I like the spd-sl pedals for all the reasons cited, the float with the yellow cleat has always annoyed me. In addition to the advertised 6 deg rotational float, there is also a significant amount of lateral float (where the cleat moves laterally in the pedal effectively changing your Q factor or stance width). Shimano have started to acknowledge it now in their product literature but it's is significantly more than the 2mm or so that they quote.
It can be tempered by cranking down on the pedal tension, but that also limits the movement of the cleat rotationally.
I have found the blue cleats to be a good solution with the pedal tension backed off completely. Enough rotational float for me and no lateral movement.
Otherwise, the spd-sl design is the best on the market. Completely reliable, the best bearings around and pedals and cleats last a good long time.
Juanmoretime
Administrator
by Juanmoretime
RESIDENT GRUMPY OLD MAN.
Asteroid
by Asteroid
Red cleats (fixed mode) all the way, fellas. I never liked the feel of floating cleats, so have always used fixed ones for the past 22 years. Both cleats and pedals last much longer, too.
Oldbie
BdaGhisallo
by BdaGhisallo
Red cleats would be ideal, but some of us have mechanics that require a little float. I am envious.
PinaF8
by PinaF8
I've been using DA9100 pedals for a month now with blue cleats and they are by far the best compared to Look carbon ti keo and speed play. Butter smooth bearings, adjustable release, and wide cleats.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
Juanmoretime
Administrator
by Juanmoretime
What cleat comes standard with the pedals?
madik
by madik
Juanmoretime wrote:What cleat comes standard with the pedals?
Ultegra, 105, PD-R550, PD-R540 - Yellow one
Dura Ace - Blue one
Code: Select all
SH10 Red
Fixed position with no float for complete efficiency and rigid form
SH12 Blue
2° of float for a balance of comfort and efficiency
SH11 Yellow
6° of float for comfort, ideal for riders whose feet move naturally during their pedal stroke
edit: my Ultegra pedals came with Yellow cleats. I thought its for all series..
Calnago
by Calnago
Last few boxes of Shimano dura ace pedals that I've opened up, pretty much ever since the blue cleats were released, have all initially had the blue cleats supplied with them.
Asteroid
by Asteroid
My brother held that same belief for many years, until he made the switch to fixed a few years ago. With no ill effects, whatsoever. :thumbup:
Oldbie
shimmeD
by shimmeD
One does wonder how much a case it was the onset of floated pedals fixing a problem that really never existed similar to disc-braked road-bikes. I stared off with straps (fixed) moving on to Time etc etc including S-play. My knee started going in-out in the pedaling motion, so I thought 'right I'll fix this by trying fixed cleats'. Now I'm on SPD-SL pedals red cleats and couldn't be happier.
2 pairs of Dura Ace pedals both came with blue cleats, and I haven't even tried them.
Less is more.
cyclespeed
by cyclespeed
I use blue cleats on DA pedals (9000, now 9100).
Tried red last year, but just couldn't get on with them, so went back to blue.
Calnago
by Calnago
I love the red myself, so long as they're dialed perfectly. To me, they don't even feel like they're fixed with no float. I generally just trace the outline of the old cleat with a white bistro marker when changing to ensure I get it in exactly the right spot. Word of warning if switching between cleats... Give yourself a few practice clip ins clip outs if switching between the different colors. A couple of cleat changes ago I thought I'd try the blues. Set them all up perfectly, no test ride, friend rode over and I just jumped on the bike and off we went. First stop light, boom, I went down when I didn't clip out right away. No damage except to the ego, but very embarrassing. Simply didn't even think about any real different feeling when unclipping. Lesson learned, and my friend had a good laugh. I did have booties on, so I suppose it could have been a bit of bootie underneath the cleat that caused the issue, but when I eventually switched back to the reds I did realize a quick adjustment period was still necessary.
BdaGhisallo
by BdaGhisallo
The blue cleats do have a different sensation when unclipping than the reds and yellows do. With the blues you almost have to pull up on them after swinging your heel out.
Calnago
by Calnago
Now ya tell me... lol.
