Shimano centre lock to 6 bolt converter on fulcrum AFS
lirek15
by lirek15
Hi all,
I got a pair of fulcrum disc wheels with their AFS rotor standard and wanted to run shimano's centre lock to 6 bolt converter on them. However, since the AFS standard runs threads for the lock ring on the outside as opposed to the inside (as shimano does with their lock ring) of the hub, my 6 bolt rotor does not clear these threads and cannot be mounted. I'm using TRPs rotors that came with their spyre calipers. Has anyone encountered the same issue before? Would it be advisable to file off some of the rotor material around the bolt holes (I probably need a mm or 2 filed down for it to clear the threads of the hub)?
Cheers
