Destroyed Chris King R45 Rear Hub - Your Expert Opinion Solicited UPDATED
Mr.Gib
by Mr.Gib
I never understood why CK doesn't use titanium for the freehub. At the the price premium over for example Dura Ace, it should be a tougher material. I never put Shimano cassettes on my CK hubs for this very reason - only Sram.
sugarkane
by sugarkane
They stopped making those alloy 'campag' freehubs a few years ago.. because they cracked, brakes and generally shat themselves. They make the new version from stainless steel now and you won't break on of those.. also if you have a good realationship with the person who built the wheel and it got the hub from still Chris King will Warrenty that..
bikerjulio
by bikerjulio
Campy freehubs are alloy, and I've never heard of that kind of problem with them. Did CK make the wall thinner perhaps? Inferior material? I'm just saying that this isn't inherent to the Campy splining. There has to be some difference.
There's sometimes a buggy.
One.
Mackers
by Mackers
Take the large CK bearings that Shimano's cassette body design allows and stuff them in the smaller diameter Campy-splined body like CK did, and this is what happens.
CK will replace it.
bikerjulio
by bikerjulio
Looking at the first photo again. If that's the wall thickness we are seeing, then it looks ridiculously thin. No wonder.
Here's the real thing. Spot the difference?
As well as the paper thin shell of the CK, notice that the inner corners of the splines are machined at a sharp angle whereas the Campy's are chamfered.
One.
beeatnik
by beeatnik
After one call to Chris King, I was sent a new stainless steel driveshell. They now have 4 splines a la Tune's Campy freehubs. Fortunately the hubshell bearings weren't damaged. Simple install and the wheel is back on the road.
Svetty
by Svetty
Sounds like exemplary response from CK.
MJB
by MJB
Good news! - we need more of it!
