Destroyed Chris King R45 Rear Hub - Your Expert Opinion Solicited UPDATED
beeatnik
by beeatnik
Patient: 5-year-old Chris King R45 Campagnolo Hub w/ a Campy 11-29 cassette
Possible Preconditions: Rain ride
Disease Onset: Short 15-20% hill, halfway up some believed chain skipping
Disease Presentation: Locked drivetrain, misaligned axle
Physical Examination:
Driveshell about 2-3mm off center
Most notched Campy freehub evah
Chunks coming off aka worst weight weenie tuning evah
DX aka what the hell happened?
MJB
by MJB
From the top image - The freehub bearings have collapsed if the freehub body is off centre.
beeatnik
by beeatnik
^In the 3rd and 4th pictures you can see parts of the free hub which shredded off. I lost the small shards which showed the inner threads. The deep gouging must have occurred just before the hub failed (play?) as the freehub was pristine a few weeks ago.
MJB
by MJB
Does the axle smoothly rotate through the body OK? If so then the hub bearings should be OK.
Does the freehub body smoothly freewheel OK? If so the freehub body bearings should be OK.
The bite / shred marks all over the freehub spines look like the cassette was moving on the body ie) maybe lockring was not correctly torqued?
beeatnik
by beeatnik
^No axle rotation.
Freehub essentially came off the hub body. Wheel rubs against chainstay in the dropouts.
Before failing, I now recall that there were a few instances when the chain seemed to skip on steep grades.
I previously used a 12T CK lockring for a 12-27 cassette. A few months back I swapped out to an 11-29 using the 11T CK lockring.
TheDarkInstall
by TheDarkInstall
First of all, well done. That is impressive, no matter how you did it.
Take is apart and get a load of in-focus photos of the various parts. Would love to see what is going on inside.
Esterhas
by Esterhas
I'm currently now on my 4th Campy freehub for my three year old Chris King rear hub. Each freehub cracked, causing chain slipping/slap & inability to spin in reverse. I'm not blessed with the technical knowledge help you with your problem, but might be something to look in to, as they are generally hairline cracks. Good luck.
beeatnik
by beeatnik
yikes, cracks seem to be the culprit(s) here as well
fun pics:
crackz is wackz
Servicing is so easy
Bearings and pawls (engagement) seem qoo
MJB
by MJB
That's a catastrophe.
Never seen that before........ yikes indeed - you powerful animal you...........
kulivontot
by kulivontot
New freehub and you should be good to go, no?
kode54
by kode54
you may need to replace the wheel bearings as well as the entire free hub. i've never seen that destroyed like that...and it doesn't look water related from riding in the rain.
- AX Lightness Vial EVO D + DA9150 + Enve SES 4.5 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Guru Praemio R Titanium + DA9150 + Enve 3.4 CK hubs
csteenbe
by csteenbe
I had also a problem with the rear hub R45 Campagnolo, bearings exploded in 5 tkm and 2,5 year, minimal of rain seen.
Talked to my LBS, would not help me and also CK left me in the cold, reason with those kilometers and years they have been serviced......
I am very disappointed in the product Chris King, will never buy it again bad product!
TheDarkInstall
by TheDarkInstall
Haha, that is full on destruction.
Wonder what Chris King will have to say about this...
csteenbe
by csteenbe
TheDarkInstall wrote:Haha, that is full on destruction.
They will do nothing, is my experience !
wheelsONfire
by wheelsONfire
Atleast they must have been leaving you with some sort of comment on this?
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
