Rotor Crank Compatability to Wilier Cento 1SR BB386 Evo Frame
theironboy
by theironboy
Hi, I currently have a Wilier Cento Uno SR which runs a BB386 Evo frame. I tried putting in a BBright rotor crank that came from a Cervelo and the crank spindle is not able to entirely reach the other side of the frame. Due to this I am not able to lock the drive side properly.
Would you have any tips on how to resolve this? Would using a BB30 crank be better?
stormur
by stormur
Bb30 shell width : 68mm
BB386 shell width : 86mm
answer yourself would it fit ;)
Now , what fits :
- any Shimano
- Sram GXP
- Rotor UBB30
- any Campagnolo
what won't fit :
-any Bb30 crank
Mark Twain
Fixie82
by Fixie82
You will need to change out the spider on the cranks. If my memory serves me right, the BBright Rotor have a wider spider, essentially an inbuilt spacer. It will probably be easier to flip the crank for a non BBright version that it would be finding a spare spider.
damond
by damond
Not the spider itself but rather the spider lockring!
You have to change this:
For this:
1415chris
by 1415chris
What crank do you exactly have?
For bb386evo you need 3D+, 3Df, Flow, Power and 3D30, so quite a choice from Rotor.
Sorry for correction of my post as I was referring to the old Rotor's pdf compatibility flie, which didn't include 3D30 as compatible with bb386evo.
All these cranks to be run on bb-right 79mm shell they need 11.5mm spacer on DS. If you take it off they become 386evo compatible.
