Record 11 Speed Rear Der - Cable Angle Question
alistaird
by alistaird
All,
My first Record 11 Speed build (and first proper Campag build as well.)
On the RD, the angle in the smallest sprocket between the cable housing and the cable looks quite large? The RD changes nicely through all 11 gears but wondered if this was normal?
ImageDSC_0026 by A&D D, on Flickr
Thanks
A
bikerjulio
by bikerjulio
The angle looks normal to me but you have the cable incorrectly routed. It goes under the clamp plate, not over it.
Here are the instructions http://www.campagnolo.com/media/files/035_260_Technical%20manual%20-%20Mechanical%20units%20rear%20derailleur%20-%20Campagnolo_Rev02_04_16.pdf
There's sometimes a buggy.
One.
alistaird
by alistaird
Thanks. I've fixed that. :-)
A
Sent from my E6853 using Tapatalk
5 8 5
by 5 8 5
It looks like you have quite a bit of wear on the inside of the pulley plate? Is the jockey wheel okay?
alistaird
by alistaird
5 8 5 wrote:It looks like you have quite a bit of wear on the inside of the pulley plate? Is the jockey wheel okay?
It was a 2nd hand RD and I've replaced both pulleys and bearings.
Thanks for the advice.
A
5 8 5
by 5 8 5
Wasn't sure if it was just the pic. Permanent marker will sort it out.
