Light (est) internal cam quick release skewers
LouisN
by LouisN
I'm searching for a light ( lightest possible) option for internal cam quick release skewers.
Besides Original Shimano Dura Ace, do you know of any other brand-names ?
Thanks for the help guys :beerchug:
Louis :)
tommasini
by tommasini
Tune AC14 at 49 grams. But from the looks of their 2017 catalog the AC-14 is no longer but the AC 16+17 combo looks to be 50 grams in a std road length.
KC
by KC
Zipp titanium versions are 53.
RyanH
by RyanH
I'm interested in this as well and have read a lot reliability issues with the Tune AC skewers. Anyone using them for awhile that have had good luck with them?
Strava
tommasini
by tommasini
I've had 3 sets used on 3 bikes - one set is over 10 years old. No problems.
kode54
by kode54
RyanH wrote:I'm interested in this as well and have read a lot reliability issues with the Tune AC skewers. Anyone using them for awhile that have had good luck with them?
just make sure you keep them clean and corrosion-free. lube the cam area with dry lube.
never had issues with the other than when they first came out. the carbon part came out of the aluminum cam section. got it replaced.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
LouisN
by LouisN
Yeah, Tune AC is thé only light reliable option I found
KC wrote:Zipp titanium versions
Looking for internal cam mate.
Louis :)
ryanw
by ryanw
Tune DC14 - 33g... I've been 107kg and smashed these to pieces, still 100% perfect.
https://www.bike24.com/p2112757.html
'16 Cervelo S5 - 6900g
'17 Focus Mares Force 1
'15 Scott Addict Team - 6850g Sold
'17 Cervelo R3D DA - 7580g - Sold
'16 Cannondale CAAD12 DA Disc - 7560g - RIP
pdlpsher1
by pdlpsher1
I have tried light QRs (Aliens 4) but they didn't work for me. I'm at 62kg and am now using Campagnolo QRs and couldn't be happier. Mavic used to make an internal cam QR with titanium rods. I believe they weigh about 85g. for a set. It's hard to find new ones and the used ones are quite expensive still. I'm afraid to switch to anything else to save 40g. and then find out they don't work. I'll stay with my Campagnolo.
userfriendly
by userfriendly
Been using Tune AC14 for over two years now, never had an issue with them.
Cinelli Saetta 6.5kg - nice and dry weather
Reilly T325 7.3kg - nice weather but windy
Spa Audax 9.1kg - all weather steel beauty
Pinnacle Dolomite 7.9kg - flat-pedal chainguard thing
M∆SON Definition 8.5kg - off-road ... thing
BRM
by BRM
What is the reason you focus on internal cam only?
DonW
by DonW
BRM wrote:What is the reason you focus on internal cam only?
Clamping strength.
LouisN
by LouisN
This.
And the ability to use the same ( mostly rear) skewers on any training or light race wheelset, on any fixed trainer before a race, without having to worry about wheel, or skewer change...
Louis :)
BRM
by BRM
Sounds a bit contradictive to me. You want a light one but a robust one . . . . :)
stockae92
by stockae92
BRM wrote:Sounds a bit contradictive to me. You want a light one but a robust one . . . . :)
Not bad, OP just want the lightest of the "robust" one :)
Having said that, I have been using KCNC Ti Skewers (exposed cam) with no issue, I am 175lb ready to run, and not a sprinter by any measure.
