FAILURE Shimano Cranksets
2lo8
by 2lo8
And NR cranks cracked despite not being hollow because something was done wrong. That’s missing the point.
Old hollow tech was not welding or bonding different pieces together, thus bond failure was not an issue avoiding the issue all together. Just because bond failure is not an issue in a crank doesn’t mean that a crank can’t otherwise be poorly designed, indeed solid cranks can have issues as well. Being bonded doesn’t make a crank immune to design flaws either.
You wouldn’t blame cracking spiders on the sweet wings being welded, so it is curious how you can blame the faults on hollowtech, not only that but those faults have since been fixed in an entirely conventional way that would be used to fix any other crank of any other construction method to deal with stress risers and lack of strength.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
pdlpsher1
by pdlpsher1
I did a quick Google and actually found many cases of the crank failures. One guy had his failed and then a friend told him that his also failed two weeks prior. Sure does sound like it's more common than people believed....
http://carlinthecyclist.com/epic-failur ... eed-crank/
2lo8
by 2lo8
Also the new cranks are still made from alloy forgings, thus vulnerable to the same faults in addition to bond failures. The cranks being compared aren’t composite and avoid the issues of alloys and forging. It’s not like the bonds are holding and the cranks are tearing along another stress riser, like if you glued two pieces of wood with PU glue, or steel tubes tearing away from brass joints for that matter. Failures are clearly occurring along the bonds.
ch00bzs
by ch00bzs
Hey guys... may i join the club ?
hambini
by hambini
ch00bzs wrote:
Tue May 01, 2018 12:42 pm
This looks like it has been dropped on it's side. Strange failure mode
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
wheelsONfire
by wheelsONfire
Strange, i have never seen any Shimano crank that has failed. Are you guys incredibly strong or what makes this?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
LiquidCooled
by LiquidCooled
The scratches/scuff marks just below the crack make it seem like there was a big impact. Perhaps this caused the failure, rather than just pedalling.
Sent from my moto x4 using Tapatalk
2017 Giant TCR Advanced Pro 0 Disc
2003 Cannondale R1000 (CAAD7)
Attermann
by Attermann
That looks just like marks from a shoe
It is really strange that more and more of these failures pop up lately...
BTW I could never understand why Shimano insists on alu cranks. Are these much cheaper to produce? A carbon crankset is better in many aspects including strength.
ch00bzs
by ch00bzs
nope it's just scuff from shoes :)
LiquidCooled wrote:
Tue May 01, 2018 3:17 pm
LiquidCooled
by LiquidCooled
Well, then I guess you're part of the club.
Vuong05
by Vuong05
Scary why so many are failing. Are all these failures during normal riding? Or was it during a race or steep incline, where huge power was put down? Regardless, it has me thinking twice now about this. I'm sure the failure ratio is minute, given how many of these cranks are out there, but food for thought.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg)
Kayrehn
by Kayrehn
Fellow clubmate had this happen to him in last weekend's race. And seeing all this... I wonder if anyone seen broken sram or campagnolo carbon cranks before? Don't want to derail this thread but just really curious to make some comparisons...
spdntrxi
by spdntrxi
I've broken an THM M3 crankarm... non-drive side.
XCProMD
by XCProMD
Yet one more in a granfondo today..
Inviato dal mio iPhone utilizzando Tapatalk
