FAILURE Shimano Cranksets
cveks
by cveks
posaunemeister wrote:
Sat Aug 17, 2019 3:19 am
I've never once had this happen to my late-generation FSA ABS cranksets. They are lighter and measurably stiffer than Dura-Ace, and the shifting is excellent. They are plentiful on eBay at the moment and can be had for half the cost. You should check them out.
share which model you use exactly.
TonyM
by TonyM
Have we ever seen any 9100 crankset broken? Or is it so far Ultegra and Dura Ace 9000?
sharkman
by sharkman
Mij first da 9170 da crank became noisy / started creaking and after changing bolts/rings for new the creak stayed. In the end the glued joint (right crank) started to work (small cracks in the black paint) and the crank was exchanged by shimano (no question asked)
Verzonden vanaf mijn iPhone met Tapatalk
XCProMD
by XCProMD
TonyM wrote:Have we ever seen any 9100 crankset broken? Or is it so far Ultegra and Dura Ace 9000?
Also 9100 series happening.
posaunemeister
by posaunemeister
cveks wrote:
Sat Aug 17, 2019 3:51 am
FSA SL-K ABS 4-bolt (I own a 52/36, 53/39, and 50/34)
"When I was young, I admired clever people. Now that I am old, I admire kind people." - Abraham Joshua Heschel
shotgun
by shotgun
martinkartin wrote:
Sat Jan 12, 2019 2:33 am
Just purchased a 9100 crankset. Has anyone run into any issues? I live in a warm tropical climate with a ton of rain half the year. I hope I can make it last.
I posted a shortly before your post, with a broken 6800, which I promtly replaced with a 9100. 16 months later, i started hearing creaking while on the downstroke of my right side. I had the BB checked and no issues and it spun well at the LBS. On a ride a week later, noise would come out during heavier pedaling. Long story short, looks like the area between the 2 bonded peices of the Dura Ace crank failed and came apart.
I've got cranks from the other brands and never had any issues. I'm swithing to a NOS sram red22 crank and just painting it black. 2 cranks in under 2 years is just ridiculous.
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
XCProMD
by XCProMD
But not unusual unfortunately. Yet no word from Shimano yet?
Skickat från min iPhone med Tapatalk
shotgun
by shotgun
shotgun wrote:
Fri Sep 13, 2019 2:19 am
9100
9100
1985 Alan Carbonio
XCProMD
by XCProMD
Looks like we got another one today, didn’t we?
And the poor chap gets to get seated on a huge Dura Ace crank display...
Inviato dal mio iPhone utilizzando Tapatalk
eric01
by eric01
Isn’t there a thread about sram red pedal interface getting loose? And a guy did his own carbon repair on it
robertbb
by robertbb
The failures of Shimano cranks appear to be centered in countries/places that have a high relative humidity...
Robius
by Robius
TonyM wrote:
Sat Aug 17, 2019 5:31 am
2016 Felt AR2
shotgun
by shotgun
eric01 wrote:
Tue Sep 24, 2019 12:24 am
Not sure about getting loose, but my old Red 10s did have some bubbling around the pedal thread area. It was warrantied (after 2 years of use)>
1985 Alan Carbonio
XCProMD
by XCProMD
I have repaired loose inserts on FSA, Specialized and Lighting cranks. Actually Lightnings had a tendency to crack. No further issues after the repair, but clearly their process was not very reliable at the factory.
wingguy
by wingguy
XCProMD wrote:
Mon Sep 23, 2019 10:58 pm
That looked a lot more like a mechanic failure than a component failure.
