Parlee Altum owners- Let's Talk tire sizes
JimV
by JimV
It depends on the wheel.
Pave27's on 202's no problem, but on 808's you can get rub on the chainstays. Something like a one of Mavic's rock stiff aluminum wheels. you could probably run a 30mm. It also is about tire pressure. If you run your 28mm and 100+psi the tire is more than likely wider than 28mm
It depends on the wheel and how much power you put out and how neat you are out of the saddle
Altum owner
boots2000
by boots2000
This^^^
I just got one too-
I am running 700x28mm Schwable One tires on the regular width (wider than a normal rim but not plus) Hed Belgium rims.
RichTheRoadie wrote:Doesn't mean you can't still buy them!
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
In a similar-but-different note, how do rims like the HED Stinger 4s fit? They're already 28mm wide, so I'm nervous about committing but I can't 'try before I buy'.
boots2000
by boots2000
My guess is yes- but I only have a set of Enve 4.5- nothing closer than that to check with.
RichTheRoadie wrote:In a similar-but-different note, how do rims like the HED Stinger 4s fit? They're already 28mm wide, so I'm nervous about committing but I can't 'try before I buy'.
RichTheRoadie
by RichTheRoadie
So we're confirmed on the 28c Vittoria Corsa Graphenes fitting the Altum, right? Anyone with the tubular version confirm 100% for me before I commit?
I'm thinking the Anthracite sidewall version could look quite cool on mine...
sureal
by sureal
Do you guys mind sharing where I can still buy them, better with discount ?
sureal
by sureal
#pls ignore this due to duplicate post#
Mr.Gib
by Mr.Gib
RichTheRoadie wrote:So we're confirmed on the 28c Vittoria Corsa Graphenes fitting the Altum, right? Anyone with the tubular version confirm 100% for me before I commit?
Vittoria 28 mm tubular should fit. I have not tried them, but for reference a 25 mm Continental GP 4000S clincher on a rim with a 19 - 20 mm internal width fits with good clearance. That combo is probably as big or bigger then most 28 mm tubulars.
RichTheRoadie
by RichTheRoadie
sureal wrote:Do you guys mind sharing where I can still buy them, better with discount ?
You mean the Altum R, or the Vittoria tyres?
I can't share my contact for the Parlee I'm afraid - you'll have to just find a good price locally or online.
