Mother of God. What happened to my bike [pic]
jekyll man
by jekyll man
martinko wrote:
wingguy wrote:
Shrike wrote:Too tired last night to search the link for a part, will try today. Emailed Workswell to see if they had a spare part..
On any major brand that would be a warranty frame replacement.
It might not be, because carbon frames tend to have it forbidden to use them with indoor trainer.
This might be one of the reasons why. I have never thought why should there be a such problem.
To be fair, a neo isn't an ordinary trainer that clamps by compressing the skewer.
Official cafe stop tester
Svetty
by Svetty
If only you'd stopped to think and paused before bending it right off..........
Even if you located the small broken off piece it's likely quite bent out of shape now. Even so retrieving it and epoxying it back in place so as to restore the flat continuous surface of the drop-out is better than nowt.
I wonder if Workswell are intending to mail you a replacement mech hanger and not the drop-out reinforcing plate.......
A carbon fibre repair shop is your best bet.
wingguy
by wingguy
martinko wrote:It might not be, because carbon frames tend to have it forbidden to use them with indoor trainer.
Do they though? I have never seen that actually stated in an owners manual or warranty terms.
Oswald
by Oswald
They will probably send you a derailleur hanger, which is not what you need. The replaceable hanger sits on the ouside, what you need is the reinforcement part that goes on the inside. I don't think those are available seperately.
mattr
by mattr
wingguy wrote:Do they though? I have never seen that actually stated in an owners manual or warranty terms.
I've seen it on 2 or 3 frames, very light, and all 12~15 years ago.
Not seen anything recently, this is either as i've not bought a road bike (light or otherwise) for near enough 12 years....... or because they've stopped doing it.
gewichtweenie
by gewichtweenie
http://www.bmc-switzerland.com/us-en/su ... rbon-care/
Carbon frames are not suited to use on home trainers with a fixed rear axle. When the wheel cannot move then the excessive loads on the dropouts can damage the frame.
dj97223
by dj97223
Bummer, but probably not a huge deal, assuming you can still clamp a wheel ok. Just keep an eye on it now and then. The good news is that it is in a spot that doesn't affect the aesthetics of the frame.
TheDarkInstall
by TheDarkInstall
Layer up JB Weld on the part that is now missing the metal plate, to form a new surface.
CummoY
by CummoY
Had exactly the same thing happen on an OEM 2015 Venge after also riding on the trainer ( KICKR), Spesh replaced it under warranty. I did ride with it missing completely for a race and noticed the carbon slowly crushing, suggest you find a fix and not keep riding as the wheel pulling over won't be fun.
Shrike
by Shrike
@CummoY any idea how exactly it happened? I've emailed back to Workswell and changed my tune a bit, suggesting that this was a defect and to get advice from their mechanics on it. Rather that just saying I needed a part as something fell off my bike :o
By the replies this seems to be ultra unusual. I've never heard anyone else have this problem before myself..
jekyll man
by jekyll man
Thinking about this a bit more (and reading on another forum), is it possible you've used the wrong spacers, or not correctly torqued up the cassette onto your Neo??
Then the lockring has either unwound, or if the cassette is fitted incorrectly and thus too far over, the lockring has then caught on the dropout tearing the protective plate off..
GothicCastle
by GothicCastle
This is not true.
mattr
by mattr
Yes it is.
Some brands recommend against it.
Chris_W
by Chris_W
After recalling all of the 2016 Venge Vias bikes due to a rear dropout issue caused by hometrainer use, Specialized are now updating their owner's manual to state that the warranty is void if any of their carbon bikes is used in an indoor trainer.
moonoi
by moonoi
Funny I had something similar happen to my tarmac SL4 today, never used on a turbo trainer. Got a puncture during my regular Sunday morning ride, popped the wheel out and fixed the flat, putting the wheel back in the metal insert just fell off! Been told that it means the frame is toast, but will confirm with the specialized dealer later in the week :-(
