Cutting a carbon seatpost
MattSparkes
by MattSparkes
Can I get away with cutting to the red line, or maybe even orange? Is it a good idea to put a slant in there, like the Fizik posts? Also, what should I coat a carbon post with in an alloy frame? It's a very tight fit and only just came or after a few weeks use. Some lacquer seems to have worn off and left an irregular surface on the post - there was much wiggling to get it out, so it's probably from that...
Frankie - B
Administrator
by Frankie - B
Moved to Road by me. Please let us know if this is the wrong forum.
May I suggest that you post a picture of the seatpost, or mention the brand at least?
A rule of thumb for cutting seat posts is that you let it at least extend 1.5 cm past the bottom side of the top tube. slanting means that you can cut it shorter. Roll tape around the place where you want to cut and saw, with a sharp blade through the tape afterwards, finish the cut with nail polish or varnish.
Please follow me on Instagram
vanmatthew
by vanmatthew
What do you mean finish the cut with nail polish or varnish? To remove the paint?
If you want to be safe, just measure the distance of the current safe line and just make sure that much is available after the cut. You can get more material off with a slant cut but I don't know if it will work with carbon. Fizik may have added extra carbon to shape it that way.
Raccooningtanuki
by Raccooningtanuki
Frankie - B wrote:Moved to Road by me. Please let us know if this is the wrong forum.
Should the nail polish color match your frame or accents? Is glitter ok?
Spring propel viewtopic.php?t=140915
Fall guru merus viewtopic.php?t=155877
Summer carver nonsense viewtopic.php?t=156795
Frankie - B
Administrator
by Frankie - B
The nailpolish needs to glitter and be bright pink.
No, you need to nail polish to bind the strands of the carbon on the face that you cut together again.
@vanmatthew, this is weight weenies, not keep it within standard weenies ;) I have cut a couple of seat posts and it always works.
Marin
by Marin
Or just cut it with a saw or dremel, insert and ride. Noone is going to see the bottom end, and you don't really need to seal or finish the cut. That's the way I do it with my steerers and seatposts.
Juanmoretime
Administrator
by Juanmoretime
I just use a proper cutting guide with a brand new hacksaw 32 tooth blade every time I cut a post or steer tube. I wrap the area to be cut with a layer or two of masking tape. Mark my spot to be cut after measuring it a bunch of times to be sure I'm cutting it in the right place, can be pretty expensive cutting it in the wrong place. I alway like a 100mm of post to be inside the frame. Once cutting I cut 1/2 way thru and rotate then cut from the other direction. Then I lightly sand the cut area and tend to put a slight bevel in the clear coat to make insertion a bit easier. Add carbon paste with a seatpost and properly toque.
RESIDENT GRUMPY OLD MAN.
F45
by F45
I balance it on my knee and hit it with my battery powered sawzall. When you ram it in the bike, any carbon shavings will get knocked off. Pretty easy.
cyclespeed
by cyclespeed
F45 wrote:I balance it on my knee and hit it with my battery powered sawzall. When you ram it in the bike, any carbon shavings will get knocked off. Pretty easy.
What is a sawzall?! Like a chainsaw?! I'm sure that's a very fast way to do it!
F45
by F45
I guess they call it a Hackzall. I use the Milwaukee M12 model with the metal cutting blade. You can zip tie the vacuum hose to the underside of the metal guard and catch 99% of the carbon dust. So cash.
pdlpsher1
by pdlpsher1
I use a chop saw with a carbide blade designed to cut wood. No taping of the post is needed and the finished cut is as good as the factory cut. No splinting or fraying. I also use the same carbide blade to cut aluminum and it goes through aluminum like butter.
dpkinard
by dpkinard
I've used a pipe cutter before, with the small wheel that you tighten one turn and spin around the fork, tighten, spin repeat. It's always going to be straight and 90 degrees.
Sent from my SM-G920V using Tapatalk
kkibbler
by kkibbler
dpkinard wrote:I've used a pipe cutter before, with the small wheel that you tighten one turn and spin around the fork, tighten, spin repeat. It's always going to be straight and 90 degrees.
This is bad for carbon. You want to cut the fibers, not crush them until they break.
