Specialized S-works road crankset (2017) weight
endershan
by endershan
Got my crank shipped in today, it has 130mm spider and 172.5mm length. The chainrings are Praxis 53/39. It's not light, but hopefully the new design will enhance stiffness and reduce the possibility of creaks.
cyclespeed
by cyclespeed
Interesting, I didn't know they'd changed the axle design.
I thought it was a pretty good design. I've had 3 sets and never had a problem. Very easy to remove for cleaning.
If I do ever get a creak (rare) it's because it needs a touch more grease, but this is a 5 minute job so not a problem.
https://www.youtube.com/watch?v=d3l2jY6yi-8
endershan
by endershan
cyclespeed wrote:Interesting, I didn't know they'd changed the axle design.
No 2017 specialized bikes are equipped with this crank except S-Works Venge Vias Disc. I wonder if road bikes with disc brake have chainline farther from the center of the bike, which could be the reason for them to re-design the crank? The spindle seems wider, I might need more spacer to install it.
spartan
by spartan
my new 2017 etap 53/39 gxp crankset with original rings weighed 605gm. if i upgrade to praxis buzz saw rings can get it to
580gm. don't think specialized will produce cranks in the future. no weight advantage vs sram/shimano.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
sun
by sun
Can you take a pic of the back of the drive side? Does it still have that lock ring that required a special tool? I'm curious if this still works with the Quarq spider for Specialized.
endershan
by endershan
sun wrote:Can you take a pic of the back of the drive side? Does it still have that lock ring that required a special tool? I'm curious if this still works with the Quarq spider for Specialized.
I don't have the crank right by me, but I can confirm that the Quarq spider still works, and the locking ring is still the same. This pic of Venge Vias Disc was taken on a test ride event of Specialized.
从我的 iPhone 发送,使用 Tapatalk
sun
by sun
Ok thanks for linking that.
romalor
by romalor
shut up Hanseunghee
Stop posting just to be able to post what you have to sell
endershan
by endershan
romalor wrote:shut up Hanseunghee
Did you mistake me with someone else? Coz I googled and that is a Korean name, which is not mine. Wrong nationality.
junchen
by junchen
I think there's a hanseunglee who is spamming the forum.. His posts have been removed and he's been banned.
Sent from my SM-G920I using Tapatalk
endershan
by endershan
junchen wrote:I think there's a hanseunglee who is spamming the forum.. His posts have been removed and he's been banned.
Now I understand! Thank you for clearing it out!
warx
by warx
Talking of the 2017 FACT crank I just got my Venge ViAS Disc Pro (not S-Works but same crank, different spider) and I am trying to fit my SRM spider. It does not fit! So it has changed shape. There's interference with the SRM cover plate (the part with the decal). Might be able to slightly relieve the crank arm with some machining. What a pain...
rcb78
by rcb78
I've got one still on order and didn't know the spindle changed. Not that it really matters, but is it still a true BB30 length spindle or did the lengthen it and you have to run spacers now like a BB30A, 386evo, or something along those lines.
Good to know about the spider, I've got a Quarq on my desk waiting for it and it's reassuring to know they still fit.
elfuinha
by elfuinha
hello
Any news about the stiffness of this crank.
And any one using this with etap???
Let me know please
Best regards
cyclespeed
by cyclespeed
I don't think you'll have any problems with stiffness.
