SRAM Etap. Six months in, how you getting on?
kookie
by kookie
kookie wrote:
Wed Aug 01, 2018 2:14 am
Well after less than 900km (bought it July 2017) of using eTap, the left shifter battery keeps draining. I have gone through 3 batteries (2 of them new in the last two weeks). Last one installed new on Saturday July 28th, went for a 3 hour ride on Sunday and now Tuesday the shifter is dead. Will be taking it to the shop this week.
Had a similar issue with Quarq Dzero power meter. After few months of waiting, Quarq finally gave me a new one.
SRAM sent me a new shifter, so far so good after 5 rides...
photek
by photek
I've been using eTap Wifli for about 1.5 years now, no issues at all. I recently used a rental bike with Ultegra Di2 and was not too impressed, it wasn't terrible but the shifters feel so complicated after getting used to eTap ;-)
2018 Trek Emonda SL, SRAM eTap, eeBrakes, Fabric alm ultimate, Venn 44 wheelset - 6.8 kg
pdlpsher1
by pdlpsher1
The benefit of Shimano's button setup is that when I shift the front I also simultaneously shift the rear. I don't think that's possible with eTap's two buttons. So in summary I can shift much faster than I can with eTap. There's also the benefit of the increased shift speed with a wired system. A guy on the internet did some research using high speed cameras and he confirmed the shift speed advantage of the Di2. To each and his own...
photek
by photek
pdlpsher1 wrote:
Wed Oct 10, 2018 8:38 pm
Yep, I guess that's correct - you can't shift front and back at the same time....however the occasions when I need to change front and back at the same time are so rare I've never even noticed this as an issue.
I've also heard/read that eTap shifts a bit slower than Di2, the fact that high speed cameras were required to capture the speed advantage suggests that the difference is not all that great :P
pdlpsher1
by pdlpsher1
How do you manage the shift the front without corresponding shifts in the rear? A shift in the rear is needed to maintain the same cadence. Anyways I don't want to start a war between Di2 and eTap. I'm merely trying to point out that each has their own advantages and disadvantages.
photek
by photek
pdlpsher1 wrote:
Wed Oct 10, 2018 9:03 pm
Just pedal harder!! Kidding...you are right, that is a pain sometimes :(
BdaGhisallo
by BdaGhisallo
photek wrote:
Wed Oct 10, 2018 8:55 pm
I complete a shift or two with the RD just about every time I shift the FD.
Gearjunkie
by Gearjunkie
It actually is (sort of) possible to, at the same time, shift front and rear with Etap.
Hold both levers (effects front shift), then release one lever but hold the other (effects rear shift, up or down depending on which lever you hold and multiple shifts, depending on how long you hold).
By the time the chain does a rev around the chain rings (and so effects the front shift) the rear shift will be complete. So is done at the "same" time.
:beerchug:
sungod
by sungod
"much faster"? irrelevantly faster would be more accurate
as above, it's possible to front+rear on etap within a short period
Jugi
by Jugi
sungod wrote: "much faster"? irrelevantly faster would be more accurate
My fingers are so fast, I can give the commands for simultaneous FD+RD shifts quicker than the FD is able to complete it's shift. I'd quess it is pretty much the same for Di2. So not much performance is lost, but of course two button pushes are always marginally easier than two + one.
octav
by octav
I have owned both Ultegra DI2/ Sram Etap and SUper Record mechanical. Maybe it would matter for some pros on the final 3kms of a race for mechanical vs electronical.
But Etap vs DI2 the difference is really too marginal.
calv1n
by calv1n
octav wrote:I have owned both Ultegra DI2/ Sram Etap and SUper Record mechanical. Maybe it would matter for some pros on the final 3kms of a race for mechanical vs electronical.
Which do you prefer? Thanks
octav
by octav
For the moment I sold the etap(which was on my gravel/cyclocross bike) to install my SuperRecord 11 from my roadbike. Want to upgrade to Super Record 12 on my roadbike.
So I would say I prefer mechanical but it's just that I like the feeling. Otherwise I would say Etap is the way to go. No cables, easy install no/low maintenance and I like how it looks.
azmio
by azmio
sungod wrote:
Tue Jul 17, 2018 6:48 pm
seanlsc wrote:
Tue Jul 17, 2018 4:11 pm
Can anyone tell me if Wifli or non wifli is better? Sounds like non wifli is problematic at times
what knowledge have you of the differential failure rate over time per unit population? if you have none, there's no objective basis for your supposition
The defective wifli RD problem is not only happening in the US and Europe, it is also happening in Asia. The buying power in this region is not as strong as in the US and Europe, imagine the pain and misery to the "victims".
I for once thought that SRAM Red represents the pinnacle in terms of quality, service and workmanship, but I was wrong. Quality is a matter of luck and with this particular Red product, there are many unlucky "victims".
My bike has been kept by the local bike shop for more than a month and there is still no response from the regional distributor. Perhaps, they have been overwhelmed by too many returns? I dont know. It makes me wonder too on why they continue selling it knowing that they will have plenty of defective products that will surely erode the brand. I will give it few more weeks and I will likely bring them to a customers' tribunal someday.
azmio
by azmio
