SRAM Etap. Six months in, how you getting on?
shotgun
by shotgun
seaneT1 wrote:...And I haven't even mentioned about the box that it came in! :lol: :lol:
Admittedly I like the box, BUT I did get the evil eye from my wife as I brought it into the house :wink:
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
seaneT1
by seaneT1
fordred wrote:
As cool as etap is, 6800 have been flawless to me for 2 bikes. Apart from the initial cable stretch in the first couple of weeks which requires a few clicks on the barrel adjuster, I never had to adjust anything till the cables needed changing. Front D shifting never missed a beat as well, but it does need trimming.
Sorry, had to defend 6800.
Oh and you should! even mine worked, the problem was the inner cable routing on my bikes, not the gears, sorry for not specifying it :doh:
glepore
by glepore
Ok, I'm about to set out on installing etap for the first time. What is the secret to getting the front derailleur set up correctly?
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
seaneT1
by seaneT1
glepore wrote:Ok, I'm about to set out on installing etap for the first time. What is the secret to getting the front derailleur set up correctly?
From what I understood, you should NOT try to set it up like a shimano or anything like that, you must simply follow the instructions from the videos that sram made. At least that's what my mechanic did: at first he tried seeting it up like he knew (shimano etc) and it didn't work..at all! Then,after a week full of problems and of continiously trying the usual set up stuff but always to no avail, he sat in front of the computer for about 15 minutes watching the videos, went to set it up again, and now, I just have perfect shifting all the time :D
sungod
by sungod
yes, as above, follow sram's instructions, that should be fine in most cases
if not, you can tweak the position to get it just right
there're so many combinations of frame and other component dimensions that there's no other sensible way to start
do check the clearance of limit screws with crank arm - note that the fd 'overshifts' then moves back, if there's only a tiny clearance under static conditions it's likely the screw will catch during upshift
glepore
by glepore
RTFM, thanks! :thumbup: :beerchug:
I will check the limit, external bb frame with red cranks ...
wheelbuilder
by wheelbuilder
Definitely watch the video or read the instructions in the box. As others mentioned, chainstay length, Q-factor, derailleur tab flex and other variables will come into play. Pay close attention to the hash marks on the top of the cage, and you may need to set it up slightly higher than you would any other front derailleur.
edit to add........top screw is high limit, bottom screw is low. Don't think it even states that anywhere in any of the materials.
Rex
by Rex
wheelbuilder wrote:
Thu Nov 23, 2017 10:09 pm
Upgraded to etap last Saturday after 2+years of DA 9150 useage.
Loving the etap.
As quoted, I had to set the FD a little higher than that line otherwise the cage was hitting the teeth of my chainring.
I also don't have room between the FD and seat-tube to fit the plastic spacer, but I don't think it's necessary.
Question regarding micro-adjusting the RD, does the adjustment only affect the particular gear or the whole range ?
MirkoR
by MirkoR
The Whole Range!
Juanmoretime
Administrator
by Juanmoretime
I may have asked this already but can the limit screws be set to lock out the 11th gear and use the eEtap rear on a 10 speed Red cassette? Don't want to have to replace 8 cassettes making the conversion very pricey.
RESIDENT GRUMPY OLD MAN.
Daniel1975
by Daniel1975
Rex wrote:
Thu Jan 11, 2018 8:28 am
Loving the etap.
[/quote]
2+ years 9150......? :noidea:
Charlie Chan
by Charlie Chan
Ive had mine for a year with no major problems, really like it. I do have an issue with it shifting into gear rather hard for lack of a better term. Ive tried it with Shimano and campagnolo cassettes (shimano chain) and both seem to suffer from the chain shifting into gear with a very firm loud clunk I dont get with my Di2 bike. Tried adjusting the b-screw and even the chain length but no dice.
ancker
by ancker
I've been on eTap since early 2016. Absolutely love it. So much that I bought another group to put on my second road bike.
Having spent almost two years with it, I can't stand dealing with or fighting to keep a mechanical system in tune anymore.
Shifting is perfect every time. Easy to install and set up. Everything about it is awesome.
I've never ridden Di2, so I can't compare.
izza
by izza
I’ve had it for two years with no hassles. Love it.
The only changes I got were blips made from computer mice switches from Australia.
Only change Id like to see is a firmware update to allow sequential shifting.
wheelbuilder
by wheelbuilder
First etap casualty.......... crash that resulted in broken collarbone and three broken ribs, also demanded replacement of right shifter! Still so in love with etap. Some front derailleur problems along the way, but has been perfect since then. Coming up on 2 years, and can't even imagine using Di2 or mechanical again for any reason.
