inside an eTap blip
here's what i use
https://item.taobao.com/item.htm?spm=a1 ... o5bqb40b61
cost is around 15usd and comes in 3 options
perfect for the Force AXS since it only has one slot so I can get the 2 button option
was originally going for Sram blips but opted for a cheaper one
my only gripe was that it doesn't have the clips/holder so need to make it clean when wrapping the tape
anybody with any luck ordering the taobao ones?
I made a unit to control etap with touch sensor
that is really cool, if you could slim them down slightly that would be perfect
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
campagnolo has a patent, but it is not realistic.
How do you prevent malfunctions?
https://patents.google.com/patent/US201 ... o&sort=new
Awesome, do your touch sensors also work in the same way as the actual shifters where if you hold a paddle down, it'll continue to shift? So can hold down the right button to drop down the whole cassette without needing to click like 10 times? That'd be pretty cool. Also, how sensitive are the sensors? They seem fairly sensite based on the video of shifting with your index fingers. Wouldn't want to accidentally shift if I happened to graze the sensor.
Ehm...Is there a way gto get Taobao in English?zinedrei wrote: ↑Wed Sep 04, 2019 4:39 amhere's what i use
About Force, are you saying your getting two blips per side? How?
Current
Waltly Gravel (stolen... and found!)
P-X Spitfire Ti
Fairlight Strael
Old
Canyon Ultimate SLX 6.7kg (crashed)
Tantan GR039 7.2kg (sold)
P-X Spitfire Ti
Fairlight Strael
Old
Also if there's a di2 version! I know they're easy to make but still... I'm lazykroem wrote:Ehm...Is there a way gto get Taobao in English?zinedrei wrote: ↑Wed Sep 04, 2019 4:39 amhere's what i use
Sent from my BND-L34 using Tapatalk
I used these DC power jack adapter male connector. I cut the top sides off so they would fit inside the stock Sram plugs.
https://www.amazon.com/gp/product/B077R ... UTF8&psc=1
For switches, I picked up a micro set, that turned out to be too small. I ended up using the largest 6x6x5mm switches. Anything smaller is impossible to push. I recommend something like these
https://www.amazon.com/Momentary-Tactil ... 35&sr=8-37
For wire I used a 3 wire headphone jack that I had laying around and stripped out the 3rd wire. It fit perfectly into the drilled out Sram plugs and I was able to pull the slack wire threw the sheath for a clean look. I’m going to need to unwrap my bars and figure out the exact length before installing the buttons and heat shrinking the connections. Total weight should be sub 8g. I also tested them to make sure the functioned and they fit and worked perfectly.
Ride fast Take chances
Got the final fitting for the remote "Blips" done. Super light and completely transparent under the tape. Going to take some time to get the muscle memory to exactly where they are as you can't feel them until they click.
