Look Keo Blade Bearing Replacement tutorial, any interest?
synthesis
by synthesis
Not so long ago I replaced the bearings on a customers Look Keo Blade TI pedals and in research up to the operation, I scoured the net for some pointers but came up with next to nothing. It seems that Look insist on that it only they can do the service. Well I took apart one pedal and measured the bearings inside (roller bearings only, not the Needle bearing) and bought new... however the "large bearing" I could not find a eksakte replacement for (original bearing is 18 x 12 x 5mm) but found one that would work. Are any of you interested in knowing how to do it yourself?
schmorglebot
by schmorglebot
Hi,
I'd absolutely be interested in more information regarding Looks pedal bearings.
Everyone else on the internet seems to think they're impossible to replace but mechanically its quite simple.
They're just bearings, find the same inner and outer diameter, and the same width and you're sorted.
I'd appreciate any wisdom you have to share, thanks
atakaoka
by atakaoka
definetily.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
Bogan
by Bogan
Yep! I am interested.
MAMIL? Never. O.F.I.L. yeh! (Old F**ker in Lycra)
jeffy
by jeffy
Toot!
chazmtb
by chazmtb
Yes please!
shonanmike
by shonanmike
Would be appreciated.
Ironbarista
by Ironbarista
Anything new on this?
DWatkinsBSB
by DWatkinsBSB
Mos def. Where you at, synthesis?
fignonsbarber
by fignonsbarber
I've never had a Look Keo Blade last long enough without breaking to need bearing replacement (broken 4 pedal bodies).
liam7020
by liam7020
Yep would be interested in this tutorial
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
albertop07
by albertop07
Yes
stormur
by stormur
on YT are tutorials already...
Mark Twain
spookyload
by spookyload
How did you get the dust caps to stay in? They press in, but fall out immediately when you ride. I bout new ones and get them to stay in.
Ironbarista
by Ironbarista
The YouTube videos don't have bearing replacement. I can remove and reinstall the inboard cartridge bearing but can't find a replacement in the exact size. I'm assuming the OP uses a washer but not sure hence the bump on this thread. My next option is to remove the bearing and soak it in some degreaser and then regrease it.
For the dust caps, I've seen somewhere saying use loctite. I've used little strips of electrical tape and it works so far.
