Is 11 speed Dura Ace chain compatible with Dura Ace 7900 gruppo?
wootenlakeguy
by wootenlakeguy
I've reviewed other discussions surrounding this issue, but haven't seen a definitive answer. Most say the width of pins in the chain is the same between 10 and 11 speed, so 11 speed chain should be useable with either 9000 or 7900 components. Some say functionality may be degraded but don't stipulate how much.
Is anyone using an 11 speed chain successfully with 7900 components?
I appreciate your input.
Guerdi
by Guerdi
Yes it is. I have been using a 11 speed ultegra chain (with kmc link) on my 7900 equipped bike. Works fine and chain is cleaner due to the siltech coating.
pdlpsher1
by pdlpsher1
I'm thinking of using the 11-speed chain on my 10-speed tandem. The 11-speed chain is lighter and it has the Shimano siltec friction-reducing treatment. For sure I'll use the 11-speed chain on the timing rings. I'll try this when the current chains wear out. I really li the Dura Ace 11-speed chain on my single bike. I'm able to get 3,000 miles from them with minimal wear.
stormyClouds
by stormyClouds
I am also using an 11-speed chain on DA 7900 with not issue. It is a 11.93.
Have had great luck with these chains and they are reasonably priced too.
nigajoa1
by nigajoa1
Yes, it works fine.
stormyClouds
by stormyClouds
stormyClouds wrote:I am also using an 11-speed chain on DA 7900 with not issue. It is a 11.93.
Meant to say KMC 11.93
879k
by 879k
It works fine.
pdlpsher1
by pdlpsher1
Good news. I'm going to try a 11-speed chain on my 10-speed tandem.
