EE-brakes
corky
by corky
I wish the spring were mounted ont the rear of the caliper........ it’s a major worm catcher here in the U.K.
sugarkane
by sugarkane
piss poor review by a moron.. but then are any of the reviews on road.cc any better
tabl10s
by tabl10s
I scored the last full pair in the U.S. two weeks ago.
www.canecreek.com/products/brakes-lever ... n-eebrakes(trying to figure how to post links).
2016 Orbea Orca OMR:
15.2lbs(6.89kg).
2013 Wilier Zero.7:
13.65lbs(6.19kg).
2016 Rca(build in-process and almost done).
2015 Pinarello F8(build in-process).
spdntrxi
by spdntrxi
sugarkane wrote:
Fri Jan 19, 2018 12:24 am
+1zillion
tabl10s
by tabl10s
spdntrxi wrote:
Fri Jan 19, 2018 3:39 am
+1zillion
The tall lanky guy is terrible.
15.2lbs(6.89kg).
2013 Wilier Zero.7:
13.65lbs(6.19kg).
photek
by photek
tabl10s wrote:
Fri Jan 19, 2018 6:14 am
+1zillion
It really was a terrible review, he fits $600 brakes with 2 year old cables - and then complains the return spring is not strong enough?!?! Really...? :shock:
jih
by jih
Imaking20 wrote:
Mon Jan 15, 2018 2:29 am
This reviewer seems like a moron. How about your bars banging against the top tube from a similar "incident" - do we fault the bars?
To be fair, if a bar had a sharp point right where it contacts the top tube we probably would
Imaking20
by Imaking20
...except how much that would vary by frame, bar, and the size of each.
Current:
T2
Retired:
Vermu
by Vermu
+1zillion
And in some cases the casings will have to be changed in order to work well.
At least to my old sram aerolinks the casings were too short.
sungod
by sungod
does anyone have a spacer (the ones used to adjust for rim width when mounting pad holders) for the current model that they can measure for me?
inside and outside diameter
thickness
i've got all four installed at the moment so hoping to avoid taking off a pad holder to measure
AZR3
by AZR3
sungod wrote:
Tue Jan 23, 2018 4:25 pm
thickness
Inside-7mm
Outside-12.65mm
Thickness-2.00mm
sungod
by sungod
hidefguy
by hidefguy
Fyi I bought these from Planet Cyclery for $260 + no tax since i'm in California. Cheapest i can find.
https://planetcyclery.com/canecreekeebr ... qEQAvD_BwE
kode54
by kode54
that's a great price on those.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
Gearjunkie
by Gearjunkie
sungod wrote:
Tue Jan 23, 2018 5:33 pm
Hey there Sungod.
If you come up with an alternative source for those spacers please let us know - I could use some more (for some reason my latest set of EEs only came with 4 spacers (one per pad) rather than 8 (two per pad) which I need for my narrower rims.
Cheers :beerchug:
GJ
