EE-brakes
sungod
by sungod
judging by the picture of the madone below, the way the headtube sticks out in front of the fork looks like it might foul on the ee brake as the cable enters centrally rather than at the side
depends how far the brake stands off from the front of the fork though, might be possible to add spacers to give extra clearance
marcelflash
by marcelflash
My canecreek regular front and rear came in at 84 and 86 gram out of the box with cable adjuster, the nut and silver ring.
Came from BR-6800 and had old zerogravity and M5 brakes but these look way better and durable than them.
Any comments on wear or play?
ipaul
by ipaul
Going to jump on this thread instead of starting a new one. I recently picked up a set of the newer style ee brakes and noticed a few things that I'm not sure are normal. Setting up using a Mavic Cosmic wheel (width 19.5 mm) and the metal adjusting nut seems awfully close to bottoming the quick release arm. In fact its scuffed up the inside of the arm. My cable alignment is good but will need to back out the screw a bunch. Currently using the standard washer set up but not clear if I need to add more? Also, on the front, the cable screw fits nicely between the release arm which allows for the extra travel. Unfortunately the rear does not as there seems to be a slight misalignment of the arm.
Is this typical and should I be concerned? Just hate for the brake to jam when pulling hard.
Thanks
Paul
ImageIMG_2763 by pasoldo, on Flickr
:P
marcelflash
by marcelflash
Mine touches too but only all te way in with I think a small rim will do. just use more washers under the brakepad holder and pull the cable tighter and the cable adjuster more out. And beware of pad wear.
sungod
by sungod
might be due to lighting/angle, but the adjuster above the lever looks odd to me
can you take an image from just a bit further back to show it fully and in focus?
as above, try adjusting number of washers/cable
ipaul
by ipaul
Thanks guys. Here's another shot. As mentioned the front straddles the nut much cleaner so figure I'd ask the questions.
Just curious is the straddle effect part of the design intent, or is the goal to keep the adjuster from coming close?
ImageIMG_2761 by pasoldo, on Flickr
:P
sungod
by sungod
still looks odd to me, i found a couple of images similar to how mine looks (these pics aren't of mine)
note the angle that the threaded adjuster makes as it goes through the lever, on yours i get the feeling it's a sharper angle, also maybe not passing through straight for some reason
did you fit both spacers each side?
ipaul
by ipaul
In regards to spacers, I'm assuming you are referring to brake blocks. Yes using as it comes when shipped, 1 black and the silver style equal on both sides. the cable adjuster rocker seems to be seating well, and I have rotated around to see if that would help but didn't make a difference. I'll try another set of wheels to see if a wider wheel sheds some light.
I've also reached out to Cane Creek, however they never seem to get back but we will see what they say.
Thanks for the help.
:P
sungod
by sungod
ipaul wrote:
Sun Jan 14, 2018 2:37 pm
ok, that may be the problem, with 19.5mm rims you should have two of the black spacers each side (plus the spherical washer)
from the instructions... 19mm to 20mm wide rims. Use 2 spacers on each side
https://www.canecreek.com/resources/eeb ... ctions.pdf
they are shipped with one spacer installed each side, the other two are in the little plastic bag
Miller
by Miller
Surprisingly lukewarm review of EE brakes in road.cc.
http://road.cc/content/review/235081-ca ... -ee-brakes
ipaul
by ipaul
@sungod, unfortunately those extra black spacers were not included. I’ll reach out to Cane Creek and try to obtain some.
Thx
:P
sungod
by sungod
Miller wrote:
Sun Jan 14, 2018 8:50 pm
the much repeated complaint about "risk of damage to your frame" needs taking with a large pinch of salt, the screw on mine comes nowhere near the frame
aside from cost, the only other complaint seems to be about the return spring strength, again i don't have that issue, the reviewer admits their cable might be the cause, yes, it might indeed be
overall felt like the reviewer is annoyed because he accidentally scratched his bike by allowing the front to flop around
people have dented top tubes doing that, it's annoying of course, but if it were me i'd be blaming myself (a lot) not the brakes
assuming these are the latest version, what could be an issue is that it looks like the offset adjuster screw may now need a hex key to use, rather than the knurled knob, to me that's a retrograde step
Imaking20
by Imaking20
This reviewer seems like a moron. How about your bars banging against the top tube from a similar "incident" - do we fault the bars?
Current:
T2
Retired:
Noctiluxx
by Noctiluxx
Erwin wrote:
Fri Aug 18, 2017 7:10 am
Sorry for reactivating this thread.
But yesterday I want to order the new(er) eebrake direct mount for my Madone 7 with new aero arch. Just before placing my order I have noticed in another shop which excluded Emonda and Madone for this type of brakes. I think the aero arch could collide with the headtube?! Nevertheless I saw some older pictures with a Madone 7 and front eebrake. Was there a special Madone version available long time ago?
The regular eebrake on my Canyon Ultimate works flawlessly with R9150 DI2 lever...
I know Cane Creek makes only rear chainstay EE brakes that should fit your Madone. I just bought a pair of front direct mount EE brakes for my Oltre XR4 as they don't make any rear seatstay calipers for the rear. With slight modification, I used the front direct mount for the rear.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2017 Giant TCR Advanced SL (Red)
2016 Specialized Allez DSW Sprint (Gold)
2016 Giant Anthem Advanced SX (FS)
2018 Trek Farley EX 9.8 Fatty (FS)
Bridgeman
by Bridgeman
Their counter spring design is very clever. They've compressed the shape in the center section to be wider in the vertical, thereby giving more spring tension without going with a thicker rod material. The center section is compressed at an angle, so the increased cross section tapers outward towards the ends, allowing the them to remain round for insertion into the brake arms. This saves weight, maintains a reasonable spring rate while achieving enough spring tension for lever return.
Cannot wait to assemble this brakeset on my F10 tomorrow.
