Stripping the paint of my TCR Advanced
jorisee01
by jorisee01
The frame as in the pictures was also 3 hours. I think the small tubes will be easier then the big ones
burglarboycie
by burglarboycie
Looking good.
jorisee01
by jorisee01
I've googled to find what wax to use in a naked carbon frame but can't find the right stuff. Anyone knows what to use?
wheelsONfire
by wheelsONfire
That was fast! I guess you did not just sand the paint off like i did?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
jorisee01
by jorisee01
Its still work in progress. Only did the downtube and a seat stay. What did you do with the raw carbon frame? Clear coat?
kevosinn
by kevosinn
Looking good! It's a lot of work but totally worth it in the end. Using a razor blade in a swiping motion removes it very quick as well as sanding. The blade leaves a perfect finish. You were talking about a wax. I use aerospace 303 for a UV protectant. Apply once a month and you will never have to worry about UV damage to your resin.
https://www.ebay.com/itm/351752414446
jorisee01
by jorisee01
I find it very rewarding. Exposing the nude carbon and finding out how the 3K weave is really fun!
Thanks pointing me to the 303. I'll look into that!
chris14
by chris14
kevosinn wrote:Looking good! It's a lot of work but totally worth it in the end. Using a razor blade in a swiping motion removes it very quick as well as sanding. The blade leaves a perfect finish. You were talking about a wax. I use aerospace 303 for a UV protectant. Apply once a month and you will never have to worry about UV damage to your resin.
I use 303 too. Great product and simple to use.
4ibanez
by 4ibanez
I've been thinking of stripping my frame and forks for a while so found this intereting. I've found a couple of local companies that do soda blasting and am thinking about that if the price is ok. Having sanded my cranks, I have little desire to go through that again and am kinda nervous about shaving the clear coat and paint with a razor.
pdlpsher1
by pdlpsher1
Just curious. How much weight can you save by stripping the frame? It's seven grams for the fork only so I'm guessing maybe 60g. for the frame only?
And would this affect the frame stiffness as the paint is part of the structure after all? Maybe not enough to be noticeable but certainly one of the many reasons why warranty would be voided.
Jengaback
by Jengaback
It depends on the bike. I stripped the paint off my alloy condor and saved around 150g but others have stripped higher end carbon frames and saved less than 100
jorisee01
by jorisee01
My frame only has clear coat and some decals so I don't expect much. I think 60 grams could be a good estimation.
jorisee01
by jorisee01
I am progressing slowly. Found some imperfections under the lacquer. What to do with that?
Here a progress pic
jorisee01
by jorisee01
I'm also going to fit this non-Di2 frame with Di2. Does anyone know how to internally route the etube cable to the RD?
pdlpsher1
by pdlpsher1
jorisee01 wrote:I'm also going to fit this non-Di2 frame with Di2. Does anyone know how to internally route the etube cable to the RD?
You want to drill the hole for the RD not on the top or bottom of the chainstay. The hole should be on the side (outside of course) smack in the center (top to bottom) of the chainstay. The center of the chainstay has the least amount of bending stress and hence it's the best location to drill a hole. I don't know what type of BB shell you have but you need to open up three holes on the BB shell for the various cables. One going to the seat tube (for the internal battery), one to the chainstay, and one to the down tube. You can hide the junction box in any one of the tubes.
