UPDATE: Rue Uberlight now 3,346g (7.38lbs)
donald
by donald
Finally, after all these years, I took 2 grams off the bottom of the bottom bracket and one gram off the front derailleur hanger, for a frame that now weighs 597 grams. I took more off the crankset, it now weighs 304 grams. The bigger reduction is from my new saddle/seatpost combo. I used my dash saddle with a schmolke post. Total weight 68 grams, and that is with a 300mm long shaft. A light saddle alone weighs that. I have about 1,200 miles on this combo; no problems (I weigh 138lbs @ 5'10'').
For a couple of years now instead of cut inner tubes for hoods I have been using a cut, flexible work glove. Lighter, more flexible ones work best, also the thumb looks better. Just cut the ends to the right shape. They have been very durable. Also I have used thin packing foam with some black "Flex Seal", a liquid rubber coating. One can spray or brush it on the foam. As time wears some of the coating away one can just add more. There are many brands of gloves, one has to find the right ones.
Carbon pad holders with all hardware is 14 grams. I recently took 1 gram off the two rear holders but I have been using these at this weight for over 5 years without problems.
Carbon bar ends, 1.7 grams the pair.
Carbon 10mm wrench for bolt-on skewers, 4.9 grams.
RyanH
by RyanH
Any thoughts on where you want to save weight next?
rma
by rma
Hey, slam that stem and cut the excess steerer... Will save you 10-20g
donald
by donald
I'd like to have a custom fork made that weights 200g or less. This frame made 9 years ago was specifically made with a very short headtube to save weight and it's a little more aero this way. Making the headtube this short saved more weight than the spacer and extra stearer tube. The spacer weighs practically nothing; would I have a heavy spacer on a bike like this?
kode54
by kode54
how's the saddle attached to the post? did you bond these together?
way to go Donald. that's a lot of tuning going on.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
donald
by donald
The saddle is attached the same way as my previous combo, the 96g combo [http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=132517]. I have been using the 96g since 2015 with no problems so I doubt there will be problems with the 68g combo.
wingguy
by wingguy
donald wrote:The spacer weighs practically nothing; would I have a heavy spacer on a bike like this?
Well, yeah. I mean, clearly you haven't thought very much about this build :wink: :lol:
That thing is epic. If you ever retire it from riding duties it shoud be hung up in the Metropolitan Museum of Art.
xena
Banned
by xena
Don, can I call you Don "your the man" :lol:
You could cut off the parts of your carbon bar ends that go inside and just glue/bond the flat circular part straight on to your bars . Could save a gram " hopefully"
A gram on your bikes counts .
As usual AWESOME .
donald
by donald
xena wrote:You could cut off the parts of your carbon bar ends that go inside and just glue/bond the flat circular part straight on to your bars . Could save a gram " hopefully"
I thought of doing that many years ago but since I change my bar tape every so often and since my bar ends are so light I have always gone with my current setup.
I know you just glue the ends on (on your bike) and I think that's great! You have done some fantastic things to your bikes! Keep it going!
CBJ
by CBJ
Soon your only option will be helium instead of air in the tubes to save weight :-)
Amazing work!
2lo8
by 2lo8
donald wrote: Making the headtube this short saved more weight than the spacer and extra stearer tube. The spacer weighs practically nothing; would I have a heavy spacer on a bike like this?
Wouldn't the steer tube be the same length no matter what the length of the head tube? The spacer just makes up for the shorter head tube. Although with a higher rise stem, you could get rid of the spacer and steerer. It would be a little stiffer in theory too. A more direct line from the supported upper headset to the handlebars.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
donald
by donald
Yes, the steerer would be the same length and my stem rises just the right amount now with this spacer. This is the way I decided to go back then and the fit has been perfect. The weight savings is basically just in having an extremely light spacer instead of more head tube. This setup is still very stiff.
kevosinn
by kevosinn
Just a great bike and project.....thanks a lot for sharing with us!
jimborello
by jimborello
Damn Don that bike is awesome!!! You make my 5.2kg bike feel like a pork =(
craciunptr
by craciunptr
Amazing! I love it and I agree you should exhibit at the moma. Could you please also post more pictures of the bike from other angles and details of the tuned parts? Would love to see the full extent of your tunning efforts.
