SI v SISL2
Yes, but my reasoning has nothing to do with stiffness and/or weight and everything to do with the redesign. 109mm spindle on Sisl2 vs 104mm spindle on Sisl. Wavy washer is on the non-drive side versus drive side. Gone is the shoulder on the spindle which prevented getting a decent chainline for DA9000 to work as it was designed.
Actually then, I am not at all sure if the new Sisl's have a design change. I thought there was only Sisl and Sisl2, and that if it didn't say Sisl2 it was first generation stuff and had the 104mm spindle. I may be wrong there so I would check that out. I am going on my experience with a 2012 or so Hollowgram Sisl crank versus the newer Sisl2 Hollowgram crank.
Yeah, but try finding a 109mm spindle these days. And even then the newer profile of the cranks or spider or combo, (can't remember which) means that it ends up not quite "right" anyway. And I forgot what "not quite right" means exactly but may have something to do with q-factor or distance from center for each crank. Probably not a big deal. The hard part would be finding a 109mm spindle I think.
Or are they used in their other cranks now as well? If so, I'll pick one up for a friend of mine who could sure use one.
Quick question for anyone who has installed a SiSL2 crankset. I just got mine off of eBay and I can't for the life of me get the spindle past the first bearing. The spindle doesn't go much past the splines into the bearing. I've tapped (ok, a little more than tapped lol) it with a rubber mallet and it hasn't budged. I'm assuming this is not normal?
- numbers505
- Contact:
You can try putting the spindle in the freezer for a while.
