Thanks, this is exactly the input I've been looking for Would you mind sharing your palm circumference (measured at the base of the thumb where the webbing starts, as per the Q36.5 size chart)?MarginalChains wrote: ↑Mon Apr 26, 2021 8:34 amI blindly ordered M in the Unique gloves, as that's what I take in Rapha which most of my other gloves are. Having to return for an S as Medium is definitely too big for me.
Q36.5 Gear
I don't have a tape measure to hand but I remember measuring it, looking at the q36.5 size chart and thinking if I'd gone by the chart I should have ordered small to begin with. So it must have been in that 20-21cm range.steveadore wrote: ↑Mon Apr 26, 2021 12:38 pmThanks, this is exactly the input I've been looking for Would you mind sharing your palm circumference (measured at the base of the thumb where the webbing starts, as per the Q36.5 size chart)?MarginalChains wrote: ↑Mon Apr 26, 2021 8:34 amI blindly ordered M in the Unique gloves, as that's what I take in Rapha which most of my other gloves are. Having to return for an S as Medium is definitely too big for me.
I had a small which was as recommended by the chart.. But it was just a bit odd (roomy). Had a crash and wrecked. Ordered the xs and it fits better. I also have their Anfibio winter glove and it's normally sized compared to a unique.. A small fit me nicely.steveadore wrote:So did you go one size down from your normal size then? Did you follow the Q36.5 size chart?
Sent from my Pixel 5 using Tapatalk
Thanks to both of you. Lesson learned, I definitely won't size up (as I was inclined to do initially).
Which model of bibs did you buy from each manufacturer?jeffy wrote:TL;DR just buy Assos
disclaimer : i bought Q 36.5 bibs. they're good .... but higher end Assos is better
Second this; what model of each were they? I have both Cento Evo and RS S9 bibs from Assos, and while overall good, they each have their issues. I've been eyeing picking up a pair of Q36.5 bibs for the summer season, but hate to spend the $$$ on something that might end up a bust.probertsqbe wrote: ↑Mon Apr 26, 2021 7:21 pmWhich model of bibs did you buy from each manufacturer?jeffy wrote:TL;DR just buy Assos
I'm keeping the medium L1 Pinstripe. It fits like a second skin which I'm not used to since I haven't raced road in years. It reminds me of how my skin suit top used to fit. The large felt a little too long and a bit loose (I'm 174cm tall, chest 39"/99cm, athletic build - lots of cross-country skiing and some weights) . When I bend over the zipper forms a wave (if that makes sense). The large jersey is also a little loose in some areas and given how thin the material is, it will end up flapping a bit at speed. The L1 is going to be my hot weather jersey which we get a lot of in the interior of BC. If I had one thing to change, it would be a slightly looser neck. That said the tightness disappears when I drop the zipper an inch which I will be doing anyways in hot weather.
I'm a 31" waist, 37" hip, 66 kg and purchased the Gregarius Ultra bib in a medium and am quite happy with the fit. I wish all bib short makers would provide the hip dimensions which Q36.5 doesn't. Then again, Castelli provides this in their charts and I'm theoretically a small but found the medium I tried in-store to be tighter than I cared for. There was no large to try on. I emailed Peter at Roadkit with my dimensions and he suggested medium in the Gregarius - good call.
I also got the Base 2 short sleeve base layer in a S/M and that fits really well and has an appropriate length for a cycling base layer. Some of my other non cycling specific base layers are on the long side. Finally I also purchased a Gobik Pacer LS jersey in large and that also fits very well. The neck is a touch loose but I'd rather that than a touch tight. I compared it to a Pearl Izume thermal jersey in M that I have and the neck is just as loose. I hadn't noticed it because the rest of the jersey isn't as snug on me as the Gobik. I'd say the Gobik jersey size range works better for me than the Q36.5 as I'm somewhere in the middle of the large. I found a chart somewhere that said a large is 97-102cm for Gobik.
Hopefully all these numbers will help someone else my size with their decisions.
Castelli stuff usually looks good and performs well, but I haven't had great luck with durability. As for bibs specifically, I have a pair of Castelli Free Aero 4 bibs and they're not bad. Materials are good, the leg grippers don't ride up at all, and the scorpion logos actually stay put (unlike years past!). I like that the chamois is both smaller and denser than most chamois nowadays -- I actually find it quite comfortable -- but would appreciate a little more front coverage. Also, the "v"-cut opening in the back of the chamois led to the different layers of foam delaminating withing a couple of rides/washes. Perhaps the worst aspect is the straps, which don't lay flat and are cut curiously narrow. Those Castelli bibs retail for US $200, and can sometimes be had on sale for $150. Assos RS S9 bibs retail for $250, and I think I bought my pair on sale from a well-known US-based online retailer for $179. For that price difference, I think the Assos is worth it.
I have a couple of Q36.5 jerseys as well as a pair of summer gloves and like them, particularly their apparent durability, so was looking at potentially buying a pair of their bibs.
How are you liking the Gregarius Ultra? I'm interested in it as well.jwaal wrote: ↑Tue Apr 27, 2021 1:30 amI'm keeping the medium L1 Pinstripe. It fits like a second skin which I'm not used to since I haven't raced road in years. It reminds me of how my skin suit top used to fit. The large felt a little too long and a bit loose (I'm 174cm tall, chest 39"/99cm, athletic build - lots of cross-country skiing and some weights) . When I bend over the zipper forms a wave (if that makes sense). The large jersey is also a little loose in some areas and given how thin the material is, it will end up flapping a bit at speed. The L1 is going to be my hot weather jersey which we get a lot of in the interior of BC. If I had one thing to change, it would be a slightly looser neck. That said the tightness disappears when I drop the zipper an inch which I will be doing anyways in hot weather.
''Just because something is possible, doesn't mean it's a good idea. It will add unnecessary complexity with little, if any, real benefit. Part of the beauty of this sport is the lack of hand holding & arse wiping.'' - ultimobici
Try the Castelli superlegerra bibs....nice compression, great pad, longer legs, super lightweight and breathable. My favorite summer bibs. Q36.5 bibs are very nice too.CyclingGiraffe wrote: ↑Tue Apr 27, 2021 9:41 pmCastelli stuff usually looks good and performs well, but I haven't had great luck with durability. As for bibs specifically, I have a pair of Castelli Free Aero 4 bibs and they're not bad. Materials are good, the leg grippers don't ride up at all, and the scorpion logos actually stay put (unlike years past!). I like that the chamois is both smaller and denser than most chamois nowadays -- I actually find it quite comfortable -- but would appreciate a little more front coverage. Also, the "v"-cut opening in the back of the chamois led to the different layers of foam delaminating withing a couple of rides/washes. Perhaps the worst aspect is the straps, which don't lay flat and are cut curiously narrow. Those Castelli bibs retail for US $200, and can sometimes be had on sale for $150. Assos RS S9 bibs retail for $250, and I think I bought my pair on sale from a well-known US-based online retailer for $179. For that price difference, I think the Assos is worth it.
I haven't ridden in them yet. I received them on Monday and I'm saving them for my really long rides.misteryellow wrote: ↑Tue Apr 27, 2021 9:43 pmHow are you liking the Gregarius Ultra? I'm interested in it as well.
I received the Q36.5 Adventure shoes on Tuesday. It's the most $$$ I've spent on shoes and they are super comfortable. Unfortunately they are going back. The right shoe is noticeably larger than the left shoe. I ordered size 44 in the Mango Orange and the left foot is nice and snug when I've wearing a Smartwool ultra light sock. On the other hand, I can slide my index finger behind my right heel when wearing the same sock. My right foot is about 2mm smaller than my left and I'm used to having the right foot a touch looser. This, however, is a big difference. I've sent Roadkit pictures illustrating the difference and they've contacted the head office regarding the issue. So hopefully I'll hear back soon
