New dura-ace R9100
ichobi
by ichobi
That latest photo is a canyon aeroad. It looks exactly like my bike. A hydro directmount ? Who needs disbrake now. Awesome.
superdx
by superdx
I would jump all over a Shimano hydro rim brake, no matter the cost. 20% gradient downhill and head-on collisions with oncoming cars is no joke!
burninglegs
by burninglegs
superdx wrote:I would jump all over a Shimano hydro rim brake, no matter the cost. 20% gradient downhill and head-on collisions with oncoming cars is no joke!
I have no problem with standard mechanical brakes. Plenty of power to lock up the wheels and if setup properly, they have lots of modulation in them.
53x12
by 53x12
ichobi wrote:That latest photo is a canyon aeroad. It looks exactly like my bike. A hydro directmount ? Who needs disbrake now. Awesome.
The rim on your wheel is basically a big disc for your brake system. Just saying.
phlip
by phlip
wingguy wrote:
deek wrote:I wouldn't call a different color a significant change...
I wouldn't call a different colour a significant change either. Nevertheless, the crank looks significantly different.
To me the cranks' shape looks exactly like Dura Ace 9000, with only the colour being different. Where do you see differences?
wingguy
by wingguy
The crank's shape is where I see a difference.
Crankarms look way fatter, chainrings look a lot wider too.
fh8425
by fh8425
jeffy wrote:looks like long cage mech, and on disc brake bike so likely dura ace level shifters
guess someone never paid attention to the "No Photo" sign on the floor
form is nice but dislike the color ...
corky
by corky
Looks like the lines between dura ace and xtr are blurring........ Gravel bike anyone?
fromtrektocolnago
by fromtrektocolnago
I think gravel bikes are taking off huge. Also seeing more older cyclists on the road. Seems smart that Shimano would want to tap into that and offer a group set with better support for gravel and for riders looking for a rear cog larger than 32. Also think its smart for Shimano to want to grab a larger share of the power meter market. For now the looks aren't big on me, but it usually takes a while for me to adjust to new looks. When the C-60 first came out I absolutely did not like the frame, but I'm slowly coming around.
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Colnago C-64 disc(ultegra) with Bora 35 wheels
morrisond
by morrisond
The Crank arms look like they are built out of the same material as 9000 Lever Blades - Gloss UD Carbon.
That would be enough to get a lot of people to upgrade even if the changes in the group are minor.
Let's just hope if it is carbon they can shave some weight this time - although the Height/Thickness of those Crank arms gives me hope.
There last Carbon cranks - the Mythical 7800C's were no lighter or no stiffer than than regular 7800 cranks.
maxxevv
by maxxevv
What you see in these picts are final mockups of the product. The cranks and chainrings are almost certain to be plastic at this point in time. That's how Shimano does their presentation at Taipei, for the last 13~14 years at least.
Which also explains why there are no chains on the bikes.
The finish of eventual production articles would definitely be better, my guess is that it will look very similar to the XTR 9000.
bruno2000
by bruno2000
There supposed to be an embargo until the end of march until Shimano will release the information officially.
euan
by euan
Thats no hydraulic rim brake either, you can clearly see an inner brake cable
gravity
by gravity
I assume the powermeter is compatible with current DA crank since FDJ was sighted testing it on the current crank? Ultegra crank can be had for cheap!
beanbiken
by beanbiken
gravity wrote:I assume the powermeter is compatible with current DA crank
I certainly hope so, i'm holding out to see what they release. It's too close not to.
Steve
BB
Coffee & carbon
