New dura-ace R9100
beanbiken
by beanbiken
cyclespeed wrote:
djwalker wrote:I have been using the new firmware with Ultegra Di2, 50/34 chainrings, and 11-28 cassette. I can shift to all 22 gears if I want to. There doesn't seem to be a restriction for me and I didn't do anything to have that happen.
That's weird, I don't get why I get the restriction, although maybe it's to do with the new RD9150?
I would guess so. I have 2 RD9150's and while stuffing about with shifting issues I fitted my second RD and the second I did that the RD self shifted out of the smallest cog into #9 and locked out 10 and 11. So that bit of programing must be in the RD.
Ahhh, coffee & carbon
kode54
by kode54
cyclespeed wrote:
kode54 wrote:its probably because the typical chain ring combo is 50/34T, 52/36T and 53/39T. 50/36T is unusual but i'm surprised that there isn't a pull down menu that you can pick large and small chain ring combos. it should be that difficult.
i just got the WU-111 and the new battery...so i going to update all my firmware soon.
Yeah, would make far more sense to just pick your big and small chainring separately from a list, but they present you with 'their' choices, like 50/34, 52/38, etc. 50/36 isn't there....
big chainrings vary. cassettes are more fixed in various ranges...but generally specific range. you would think that the option would be built in...or possible in another app upgrade.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
ak47
by ak47
Has anyone tried 32 Ultegra casette with mechanical 9100? Will it work?
jeffy
by jeffy
MM's 9170 hydro disc Defy for Roubaix has sprint shifters
Tristan
by Tristan
That looks more like the newer SW-R9150 to me. The 9170 shifters do NOT have a plug for the old sprint shifters.
Wheelworks.co.nz
New Zealand handbuilt wheels
saeie1
by saeie1
Dura-ace R9100
I am in use and I feel soft.
Be highly responsive and responsive to excellent reaction.
jeffy
by jeffy
Tristan wrote:
i know .... thats why i posted... but the bike has discs .... :wink:
BdaGhisallo
by BdaGhisallo
jeffy wrote:
Well, there are disc brakes on that Giant, so those levers can't be 9150 since those are rim brake levers.
jeffy
by jeffy
looks like it must be new sprint shifters... that have the same port as the climbing switch
will be interested if they can be set up on the tops either side of the stem, as i much rather the sram "blip" climbing configuration over shimano.
being able to configure etap click/shift pattern (left/right/up/down/both/front) with shimano sprint switches used as climbing would be my preference.
shimano climbing
sram climbing blips
kode54
by kode54
the blips are nice with the rubber covers. makes it cleaner and less obvious.
syplam
by syplam
i notice shimano makes a black version of the FD?
FD-R9100-F
anyone knows if this is the same as the one with silver cage?
evan326
by evan326
Now that pisses me off! I'd much rather have had the black one if it was out with the silver one
Ltoddokc
by Ltoddokc
Where are you seeing a black model? I looked on the shimano website and it looks to me that the renders all show a regular metal cage, the second image looks like it has an added rendered reflection.
glepore
by glepore
jeffy wrote:looks like it must be new sprint shifters... that have the same port as the climbing switch
You mean like in this diagram?
http://www.starbike.com/en/shimano-dura ... oC2KHw_wcB
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
ooo
by ooo
Tristan wrote:
jeffy wrote:MM's 9170 hydro disc Defy for Roubaix has sprint shifters
agree, looks like sw-r9150 - you can see its bulky h=13mm transition over handlebar
