Praxis Works BB conversion Removal Issues
probertsqbe
by probertsqbe
I'm trying to remove my praxis works adapter. I've followed the instructions first unscrewing the drive side and then removing the non drive side. The issue I have is that the pf sleeve has remained in the bottom bracket and is very stiff and is not budging.
Do you have any tips on how to remove the sleeve please?
probertsqbe
by probertsqbe
Some photos so that people can visualise the issue.
I've got this far with tapping a screw driver but it now won't budge.
Any ideas anyone?
probertsqbe
by probertsqbe
probertsqbe
by probertsqbe
Also the praxis works removal instructions which I've followed to the letter.
Calnago
by Calnago
You really want to be using one of these, not a screwdriver...Image
goodboyr
by goodboyr
probertsqbe wrote:Also the praxis works removal instructions which I've followed to the letter.
"To the letter"???? Except for the part where they say use a cup removal tool....not a screwdriver????
Valbrona
by Valbrona
Park Tool RT-1 and not RT-2.
by Nefarious86
Praxis video has to be one of the most well set out instructional videos I've seen for a bike related part.
Using Tapatalk
Calnago
by Calnago
Valbrona wrote:Park Tool RT-1 and not RT-2.
Actually, the Praxis BB needs the 1 1/2" diameter tool, which is the RT-2.
itsacarr
by itsacarr
That park tools removal tool is invaluable if you ever plan on dealing with servicing stuff. I have used a vacuum extension before that matched up perfectly to one side.
probertsqbe
by probertsqbe
Thanks for all the advice. Park Tool RT-2 ordered as I'll be doing this job again in the future. I've already invested in the bearing press and drifts so buying this makes sense.
headwind816
by headwind816
Another option is to use the electric holes found in the sleeve to pull out the sleeve. I did this the first time when I realized I didn't have the correct tool. It takes a bit of time, and I would use a twisting motion when pulling. Thinking back, I would spray a bit of lubrication between the shell and sleeve as it may reduce the friction. Having said all of this, the correct tool makes it so much easier.
srshaw
by srshaw
The proper tool should make a massive difference. I tried to knock out an old headset with a screwdriver and it just kept slipping off. With the correct tool one tap and it was out.
tomyboy123
by tomyboy123
Will this work with some modification (spredding)?
http://www.wiggle.com/lifeline-headset-cup-remover/
