Colnago C60 - Campagnolo bottom bracket
tadrums
by tadrums
Thx guys. Yes, I had already used the "PVC" tool to remove UT cups from previous frames.
TA
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
Calnago wrote:
I think you just like to use that special tool you made, and rightly so! :P
You got it :-D
Happy NY by the way ...!
garypremo
by garypremo
tadrums:
My C60 build is complete and I posted the build pics here: viewtopic.php?f=10&t=143075
I wanted to answer your query about the Wishbone TF82525C threaded bottom bracket cups for Campagnolo Ultra Torque.
The installation was straightforward. I used copper anti-seize grease liberally on the threads inside the frame and a thin band of blue (medium strength) thread locker on the threads of the cups themselves. Similar to joeyb1000, I like the fact that the nylon sleeve between the cups creates a watertight seal around the crank spindle.
As expected, the bottom bracket is silent for now and I am pretty confident it will stay that way, but only time will tell.
I will surely post to this thread if there is anything to report.
2016 Colnago C60 PLWH 61 CM Traditional Geometry
tadrums
by tadrums
garypremo wrote:tadrums:
Thx very much for the BB install info. Enjoy the ride!
TA
tadrums
by tadrums
Oh, did u lose any paint when U removed the OEM TF cups? Thx again.
TA
garypremo
by garypremo
tadrums - No; I was fortunate enough not to lose any paint. I had to purchase the Colnago tool to remove the OEM cups because for 2016, Colnago did not include the tool with the C60 frame set. It was not an oversight; the user manual specifically states that the tool is not included. I purchased this one for $69 USD: http://www.excelsports.com/main.asp?page=8&description=Pressfit+Bottom+Bracket+Tool&vendorCode=COLNAGO&major=6&minor=11
You will note that the write-up states: "This tool's 16 notch spline matches shell adaptors perfectly and has very low profile to prevent frame damage when installing or removing".
The amount of contact area is not much, thus I had to take care to get the wratchet wrench perfectly parallel to the BB shell and apply a good amount of muscle before the replaceable sleeves came loose.
If I may ask; where are at with your bottom bracket? Are you considering replacing existing press fit cups? Are you doing an initial build?
tadrums
by tadrums
garypremo wrote:tadrums - No; I was fortunate enough not to lose any paint. I had to purchase the Colnago tool to remove the OEM cups because for 2016, Colnago did not include the tool with the C60 frame set. It was not an oversight; the user manual specifically states that the tool is not included. I purchased this one for $69 USD: http://www.excelsports.com/main.asp?page=8&description=Pressfit+Bottom+Bracket+Tool&vendorCode=COLNAGO&major=6&minor=11
I built my C60(SR EPS)a few wks ago. No BB issues to date I just have deep disdain for press fit BBs. I have other bikes Canyon, Urgestalt, all PF. Developed BB creak in the Urgestalt I hope to remedy w/Wishbone received t'day. Not sure if I should use Loctite w/WB tho.
TA
samuelcfadams1986
by samuelcfadams1986
Guys I'm currently staring a C60 build, I believe I will be on a 58s size but wondered if anyone could link a picture of a c60 in a 58 sloping size. It's very hard to find pictures on the net and I'm worried it might look odd
micky
by micky
How's the long term reviews from those bottom brackets with threads?
Thanks
Heavyhitter
by Heavyhitter
micky wrote:How's the long term reviews from those bottom brackets with threads?
Thanks
My C60 rode close 10 k without a sound yet. BB was cleaned and regreased 2 times per year.
wilwil
by wilwil
What kind of sound do the press fit Campy cups make if they are noisy? I have a ticking noise once every revolution which goes away after a few miles.
3Pio
by 3Pio
Thanks
Since the surface where bearing rotate in the cups is not adonized.. Is there any scratches or something from removing/installing the crankset for cleaning purpose? And what u mean by cleaned/regreased? U clean just the surface where bearing rotate, or u totaly deinstall, clean the threads, then regrease threads, and install again?
micky
by micky
Thanks
Cheers, which brand/model did you use?
TonyM
by TonyM
Thanks
approx. 15tkm w/o any service/ maintenance (on my to do list for this winter however). All ok so far.
Campa SR.
Heavyhitter
by Heavyhitter
micky wrote:
Thanks
Shimano Dura Ace. Nothing exotic but does get the job done and cheap to change
