Woot! Extralite Stem
- wheelsONfire
Just be careful with torque and use carbon paste, also keep an eye at the steerer tube from time to time.
Bikes:
Open *UP* (2016.04.14)
well, i did some search and looks like other had the bite mark as well using hyperstem
viewtopic.php?f=3&t=135956
L84AD8 also posted here's bite marks with hyperstem... now i'm a bit concerned.. surprised that it's not mentioned a lot on WW forum. either that or many other use a different brand of lightweight stem?
- wheelsONfire
velomane wrote:So, wheelsONfire, would you happen to have a pic. I tried searching through your posts to no avail.
No i have no pictures saved anymore, i am sorry!
But yes, it's true.
This is the steerer clamping of a Hyperstem. The regions of clamping made small bite marks. It was obvious these bite marks started the problem.
Looking at the outcome of the cracks, it could not be mistaken.
Cracks originated and grew from same spots as bite marks and the forks were severely damaged.
I noticed due to a phase of fit where i changed stems.
First i did not believe it could be the Hyperstem and switched it to my other bike which had same problem.
Ax Lightness Helios and THM CT fork. Now let me say, CT is like most of the later THM forks, very thick steerer tube.
I would bet they offer the thickest steerer tube avaible today and still they are among the lightest forks.
Make no assumption it is a weak fork, cause it's not.
If this fork took a beating, i don't know what fork had not done it.
Further, THM uses there own solution to a-head clamp. There is no expander, the whole inside of the fork is carbon threads and it comes with it's own lock
bolt. This fork should be near bomb-proof if circumstances are fair.
No over-torque of stem (set at 2.7Nm - 2.9Nm) , all components in excellent condition previous to Hyperstem.
There are many guys using Hyperstem and i have heard many like it.
I am not here to bash Extralite and i want to point this out!
But no-one can actually say that this, what happened to me, will not happen again.
Personally, i am a firm believer this tiny clamping is adding more stress to the steerer tube and
actually, it should be same for handlebar clamp region.
Even so, i know the stem design has been tested and approved to be safe.
But since i only ride at road and followed the mounting instruction, i can only conclude it is not for me.
There are always micro-movements and if there is a larger and round/ smooth clamping area at the stem, all stress will be more evenly distributed.
I prefer the clamping of Superlogic C260. It is huge and smooth by comparison.
Or, if the WW nerve dictates the rules, MCFK stem would be my choice due to it's clamping and weight (ofcourse)!
However, i really like the combo, Superlogic C260 and Superlogic handlebar.
Weight is good, stem is stiff and feels good with the handlebar which IMO, is superbly angled.
Bikes:
beanbiken: be sure to post up some close-up pics when you do take the stem off. would like to see as well. thanks.
spud: yea, i agree.. the edges looks a bit sharp.. will check for it when i get mine. plan to use some 1000 or 2000grit sand paper around all the edges before mounting it on my addict's fork.
Well took the stem off, cleaned off the carbon paste and checked the steerer out. Sorry addictR1 I didn't take any snaps but rest assure I saw no evidence of any bite marks or damage to the steerer tube what so ever. Fresh paste and re-torqued and ready to ride. Actually just thinking about it I will whip it back off if time permits and give it a light sand to the inner edges I'll take some images at the same time and will post them.
Steve.
Steve.
BB
Coffee & carbon
Coffee & carbon
I have the HyperStem 0-6.
Took it off the steerer. No marks, grooves or cracks. I torqued it until it didn't move, and just under 3nm. I have been laying down hard sprints on this stem, and it has not damaged the steerer.
