Yes, some "sticker wheel companies" might get into trouble sooner or later... But if there's a product liability I really don't unterstand that SRAM doesn't react.hambini wrote: ↑Thu Oct 31, 2019 4:52 pmI would be a bit more worried about the certification.
Assuming it's CE marked, if a third party installs a part on it, it has to be made to the same spec as the original with documentation otherwise the certification is null and void. If someone then subsequently has an accident, the supplier can be prosecuted. This is an extreme case but I think it's only time before one of these western rebranders of chinese wheels comes up short.
This is a Force derailleur with the (hardened) steel bold on the outer cage, but the same light stainless steel secure pin, as used everywhere else, with 25-30,000kms:
The pin will still keep the cage in place but for how long, as it shows the known signs of wear? This pin needs to be offered as a spare part and the users informed, that it is subject to wear. Regarding the SRAM RED derailleurs produced up to 2016 a failure will occur much earlier as the titanium bolt will also wear:
There are already enough people that smashed their rear wheels/frames because of this - and it's also an unnecessary fall hazard.
