2016 Fuji SL
justaute
by justaute
A couple of photos. Finished the build. Even with 28mm tires (Hutchinson Sector), the total weight is still impressive. I will soon go back down to 25mm tires and that should drop another 80-100 grams or so. Also, the skewers are stock Campy. Yes...I mix brands. :)
Weight= 6.76 kg (14.9 pounds)
pdlpsher1
by pdlpsher1
Nice bike and build. But what's up with mixing up Dura Ace and Ultegra :shock:
How much do those wheels weigh? I have no place to shave weight off of my bike except for the wheels.
justaute
by justaute
I used parts from other bikes I had. Don't remember the exact weight for the clincher wheelset, but should be around 1,480g. The 35mm wheelset is obviously lighter...the tubular version even more so.
pdlpsher1
by pdlpsher1
Thanks. That would be about 300g. lighter than what I have. I want aero and it's hard to find something that is aero, light, and easy on the wallet. Btw, those rims look way deeper than 35m.
justaute
by justaute
Mine are 50. Just saying the 35mm version is obviously even lighter.
AE86Micah
by AE86Micah
justaute wrote:A couple of photos. Finished the build. Even with 28mm tires (Hutchinson Sector), the total weight is still impressive. I will soon go back down to 25mm tires and that should drop another 80-100 grams or so. Also, the skewers are stock Campy. Yes...I mix brands. :)
Just wondering why you'd choose 28mm tires for a bike like this?
JasperGr
by JasperGr
Is the space between the headtube en fork correct?
Verzonden vanaf mijn iPhone met Tapatalk
AE86Micah
by AE86Micah
That gap does look a little excessive. Here is what my gap looks like
http://s913.photobucket.com/user/AE86Mi ... v.jpg.html
Reason: deleted the quote.
justaute
by justaute
For fun...wanted to see if it would fit.
Reason: Deleted the quote.
justaute
by justaute
JasperGr wrote:Is the space between the headtube en fork correct?
Not sure. I thought the gap/space was too wide, but did check the bearings and the base-plate -- they seem fine. I will probably call Fuji about it.
AE86Micah
by AE86Micah
Do you notice any ride quality increase between 23,25,28mm tires?
Ulver
by Ulver
Looks really nice! I'm looking for a light, relatively affordable frame that can take 28mm tyres (riding hilly 300-400km brevets, the added ride quality running at 70-80psi helps). Is there plenty of clearance for the 28s? Could I go even wider or would that be the limit?
justaute
by justaute
I don't think you can go any wider. The limiting factor is not the chainstay spacing, it's the seat-tube spacing. With Hutchinson Sector 28 on a 17c internal rim width, there's only about 2.5mm-3.0mm of room between the tire and the seat-tube. There's about 5.0mm spacing to the brake bridge. Plus, the Ultegra/DA brakes will not allow anything bigger.
justaute
by justaute
Last pic of the build. Did a 45-mile ride this morning.
DavidMLee
by DavidMLee
Fuji does not enjoy cool factor unlike other manufacturers..
But it does make absolutely good bikes.
Bikeradar tested FUJI sl, and it proved to perform very well.
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
