Focus Izalco Max
doogie2304
by doogie2304
all of the 2014 and 2015 izalco max bikes had the acros headset. as far as i can tell from the photos, all of the 2016 bikes have a fsa (or similar) headset.
as for the 2016 range, it appears to be mainly different paint jobs and a few specification changes.
i would suggest getting a 2015 model so that you can maybe pick up a sale price.
Dombi
by Dombi
Ok thanks. But the frame is the same?
doogie2304
by doogie2304
as far as i know, but you really should speak to a focus dealer, or email focus directly.
Krull
by Krull
CP wrote:
Krull wrote:
Change out the stock Headset for an FSA or something else. Trust me
Thats what i am going to do next, thanks!
sorry vor mai bed englisch!
CP
by CP
The Acros Headset was speced on all 2015 max bikes. The 2016 line up ; just cosmetic changes
sover
by sover
As I know Focus bike starts recall Arcos Headset for safty issue.
and 2016 frame is same as last year.
garlet
by garlet
Focus Izalco Max 3.0... it's so light weight bike!
sooni
by sooni
Krull wrote:Yes, 54 probably best. I am 173/85 (yes, very "leggy") and riding 52.
Note: izalco max comes with "acros the clamp" headset, which has a 17 mm top cap.
I see you have short reach for your height. What size stem do you have? I am 171/80 and debating a 50 or 52. I've tried both with 90cm stems and am still debating...
reedplayer
by reedplayer
i have nearly identical measurements (174/85), and riding a 52 as well. 100mm stem 6°, topcap 15mm, bar 80 mm reach.
i would recommend you framesize 50.
sooni
by sooni
reedplayer wrote:i have nearly identical measurements (174/85), and riding a 52 as well. 100mm stem 6°, topcap 15mm, bar 80 mm reach.
Very nice bike. I think I am going to pull the trigger on the 50cm. I get the shorter reach only at the expense of the 5mm smaller wheelbase and 5mm of stack height. This way I could toggle between a 100mm or 90mm stem, while I would have to stick with the 90mm on the 52.
mariosimas
by mariosimas
nice build. here is mine:
Naturel
by Naturel
Hello,
I am interesting to buy a new Izalco Max Disc but I hesitate for the size.
I am 1.76m with 77.5cm inside legs with 70.9cm for the saddle.
Could you give me your opinions?
Thank You.
mike001100
by mike001100
I measure 175 cm, 80 cm inseam and ride a 52 cm, soon with a 0 offset post, should be perfect. 100mm stem now, will try a 110 mm...
My saddle height is 70.6, so I find it strange that you have a 3cm shorter inseam but a higher saddle... hm?
asiantrick
by asiantrick
178 cm height, 77 cm inseam (long torso)
Ride a 52cm, 15mm set back and 120mm stem
Naturel
by Naturel
After correct checking 80 inseam
