201X Allez Sprint
CrankAddictsRich
by CrankAddictsRich
Yes.. this was my impression as well when I looked closely at one.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
estrin
by estrin
Does anyone have any tips for centering SRAM Red Aerolink brake on the rear? My front one sets up just fine but the rear is having issues centering and retracting on the NDS. I've played with cable housing and cable tension but nothing seems to work. Any tips?
perplex
by perplex
estrin wrote:
Fri Jun 29, 2018 4:08 am
I had the same issue on my Boardman - I changed from regular cable to Jagwire links and added 1 link in length. That solved my problem.
A Dane relocated to Sydney...
pyrahna
by pyrahna
I hate to say this, but ditch the SRAM brakes and go w/ the Ultegra or Dura-Ace ones. I noticed a better brake response especially with wide rims (CLX 64). The force brakes I had and the Red brakes I've tried were not as good, and my shop has struggled to get the red ones to stay aligned as well. They have also been equiping bikes w/ the jagwire links to help it though. I love SRAM stuff, one Allez is 1x Force and the RHC is etap, but both have Ultegra brakes for these reasons.
Sock3t
by Sock3t
Where is everyone weight wise with shimano groupsets? I still feel like my bike is on the heavy side.
IrrelevantD
by IrrelevantD
Sock3t wrote:
Sat Jun 30, 2018 1:24 am
My 56 full 6870 Di2, Without wheels, is at 6.6kg. That was with Fly12 & Fly6 cameras and a Garmin Edge 810 mounted, as well as a relatively heavy Brooks C15 saddle.
There are people on these forums that have done sub-7kg builds with wheels, I want to say in a 54 or 56.
Sock3t
by Sock3t
IrrelevantD wrote:
Sat Jun 30, 2018 2:36 am
I'm guilty of comparing two different scales right now. I know I have several areas that aren't expensive to shed weight, so I'll look to those for now.
mpulsiv
by mpulsiv
I spent years training and racing on Ultegra brakes. Recently, I upgraded to Dura Ace 9000, which perform quite well. It put a smile on my face for short term, until I built another bike with Campagnolo skeleton brakes. $50 Potenza brakes put my Dura Ace to shame. Same wheels were used on 3 builds and same pads. Modulation is fantastic and they stop on a dime. Dry or wet, always Kool-Stop salmon pads. I tossed Dura Ace brake pads in garbage. Based on direct experience, I will never do another build with Shimano rim brakes.
bikesrdangerousmmk
by bikesrdangerousmmk
mpulsiv wrote:
Sat Jun 30, 2018 8:07 am
Can 58/6800 series Shimano brakes be used with the Sram 1x levers I have on an Allez Sprint?
pyrahna
by pyrahna
bikesrdangerousmmk wrote:
Sat Jun 30, 2018 7:51 pm
I have 8000 series brakes on a Force 1x build and an Etap build. The pull ratio on the 6800 I think is the same, so I don't see why not.
spartan
by spartan
campy uses much better brake pads. the ultimate rim brake caliper is the 9100. a little heavy. massive power/stiffness/modulation.
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
Sock3t
by Sock3t
I went almost full (still 105 crank) 9000 group set from 105 that it came with. It's a dream to use.
bikesrdangerousmmk
pyrahna wrote:
Sun Jul 01, 2018 12:29 am
Thanks. The sram brake modulation and pads have been terrible on the same Hed wheels that used to stop reliably with 6800 brakes. I think I will have to try swapping to dual pivot brakes. Any pad preference?
mpulsiv
by mpulsiv
Yes, dual pivot brakes will perform better. OEM pads are terrible across the board and modulation is the key from best to worse: Campagnolo -> Shimano -> SRAM.
Toss OEM pads in garbage, they are harsh and made for longevity. Pick up Kool-Stop salmon pads, they perform very well in dry/wet. I have been using them for many years, rain or shine for training and racing.
www.jensonusa.com/Kool-Stop-Salmon-Road ... ad-Inserts
bikesrdangerousmmk
Perfect. Thanks.
