201X Allez Sprint
frohrider
by frohrider
Another pink build 8) - ordered back in May '17 it did find its way finally. Build weight ended up slightly over 7kg (7.1kg/15.6lbs) - no need for superlight parts on this bike by now. Still getting used to the handling..
Had to add some decals to the chainstays - the bike looked to 'silent' for a racebike :P . Did them in orcal fluorecent vinyl and the color match pretty closely.
Parts.. Campagnolo, Rotor InPower, Praxis Works Rings, Mavic Ultimates and a Berk Saddle. Stem is not final as a need to find out if a 130mm would be a better fit.
Supersix HiMod, Supersix EVO HiMod, Crux, CaadX, Lynskey R330 & Pro29, Yelli Screamy 29
CrankAddictsRich
by CrankAddictsRich
frohrider wrote:
Fri Mar 09, 2018 7:36 pm
Had to ad some Decals to the Chainstays - the Bike looked to 'silent' for a racebike :P .
That looks proper.. great build.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
mvcap
by mvcap
mvcap wrote:@CrankAddictsRich try calling The Bike Lab in Oklahoma City as they still had that frame available as of a couple days ago
Saw it today, Allez Sprint Graffiti size 54 is available at The Bike Lab in Oklahoma City.
CrankAddictsRich
by CrankAddictsRich
mvcap wrote:
Sun Mar 11, 2018 6:55 am
Thanks guys... my buddy ended up picking up a Venge
TLN
by TLN
I've noticed that my seatpost is sliding down a little. It hard to notice during one ride, since it moved just a little, but still.
Does anyone else have same issue? What do you do with it? Should I try carbon grease, or something else? I don't want to crank those two screws, as I'm afraid It might crack the seatpost because of a shape
IrrelevantD
by IrrelevantD
TLN wrote:
Fri Apr 20, 2018 7:25 pm
When you tightned down the clamp, did you use a torque wrench and verify you have enough torque on it? Carbon paste wouldn't hurt, but I'm just under 100KG and I've never had an issue with the post slipping without it. I did have the seat rail clamp slip on me once, but I know I had it under torqued on that occasion.
TLN
by TLN
IrrelevantD wrote:
Fri Apr 20, 2018 10:19 pm
Same for me. I'm around 100kilos, may be a bit over it.
I don't have a torque wrench (need to get one). Will try to put more paste today and see how it goes.
by Nefarious86
Carbogrip
Sent from my SM-N950F using Tapatalk
Using Tapatalk
TLN
by TLN
Tried carbon paste that I had at home. Seems to be working, but need to ride a little bit more and see.
topflightpro
by topflightpro
I had to use a lot of carbon paste to keep mine from slipping, and I'm well under 100kg.
Kesselflicker
by Kesselflicker
Build from my Sagan soon ready. I waiting for a straight seatpost, saddle and pedals.
hanakuso1
by hanakuso1
There's a new limited red hook colorway. I like last years a lot better. 2X coming out in July and they're also coming out in the track frame edition later
https://www.instagram.com/iamspecialized/?hl=en
https://www.specialized.com/us/en/speci ... t-espresso
IrrelevantD
by IrrelevantD
hanakuso1 wrote:
Fri Apr 27, 2018 6:28 pm
Sooo tempted.... but I don't have any bikes left that I can sell to pay for it.
mule
by mule
Ordered. While much more polarizing than last years, both are, in my eyes, art. I hope specialized continues to use the allez red hook as a performing canvas.
