201X Allez Sprint
wheelsONfire
by wheelsONfire
hasbeen wrote:That has got to be a horrible ride with that seatpost.
+1
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
SLCBrandon
by SLCBrandon
KWalker wrote:Wondering if it still has the ultra old, ultra tall geo.
Do any of you actually weld AL? Welds look nice and sturdy to me. Not sure why they used that post and did not build an elastomer into it or something to help with dampening.
The geo is actually much more aggressive. So much so that it bumps me back to a 58, unfortunately....
Hoven
by Hoven
Do you have some information about the geometry?
53x12
by 53x12
Is this frame actually designed to be aero or just to look aero?
Zitter
by Zitter
So basically a crit banger bike.
ak47
by ak47
Interesting frame, but 1x drivetrain only compatible at the moment.
CulBaire
by CulBaire
I want! I am a big fan of the 1x setup and it would make a fantastic crit bike!
Sent from my C2105 using Tapatalk
Stolichnaya
by Stolichnaya
The 2x frame with FD hanger will apparently come 3 months after the 1x frames are released.
The BB is 3-piece but still a solid chunk that looks stiff.
I have never had much affinity for Sinyard / Specialized, but this frameset looks highly intriguing.
rothwem
by rothwem
KWalker wrote:Do any of you actually weld AL? Welds look nice and sturdy to me.
This. The welds are fine. They just stick out because they're butt welds instead of fillet welds.
This bike looks awesome, but I'm not a fan of proprietary seatposts. I'm big and I crack them fairly regularly, I prefer my inexpensive $99 Williams cycling carbon seatposts.
Does anyone know if the regular Allez has been updated as well? I've heard stiffness was an issue with the older frames.
joepac
by joepac
The bottom bracket appears to be updated to smartwelds on the "normal" allez as well. I believe this wasn't the case in past years and is supposedly a big reason for increased stiffness on the Allez sprint.
HillRPete
by HillRPete
rothwem wrote:I'm big and I crack them fairly regularly, I prefer my inexpensive $99 Williams cycling carbon seatposts.
OT but why do you prefer them if you're getting repeated failures?
rothwem
by rothwem
At the risk of dragging this thread offtopic, I use them because they're light and ride nicely. I also don't want to sound like I'm trashing Williams--I'm not. I'm only on my second Williams post, but I've cracked an Easton EC70 post and a Felt brand post as well. I'm not sure if its through hamfisted overtightening, or just my fat ass smacking down on the seat on potholes and railroad crossings. I usually use a torque wrench at home, but during the first few rides of a new build I've got to adjust the seat position out on the road, so my carefully dialed torque wrench use generally means nothing.
The point of my comment is that I tend to break seatposts, and I'm thinking that that aero post is going to be quite pricey to replace if I were to crack it.
jeffy
by jeffy
hard to tell but is that pseudo-zip ties to hold the rear brake cable on the top tube?
nathanong87
Resident master of GIF
by nathanong87
yes zip ties. i think this was pre-production.
also im waiting for the FD version to release.
also that's a huge RD cable loop
Calnago
by Calnago
Sometimes I wonder if frame designers even consider the whole package and the consequences of their design when everything is built up and has to be ridden. Not sure how they're going to avoid some really nasty cable bends going into that rear brake. Result: Nasty braking.
