201X Allez Sprint
mvcap
by mvcap
Thanks, great looking ride!
07stuntin6r
by 07stuntin6r
mvcap wrote:Thanks, great looking ride!
Thanks! Sworks crank I hope will tie it all together. Later after i get a 11sp groupset either aerofly or aerofly vias
Sent from my SM-N950U using Tapatalk
Sock3t
by Sock3t
The vias is for the venge.
07stuntin6r
by 07stuntin6r
Sock3t wrote:The vias is for the venge.
Well the 25mm rode bars that came on it
07stuntin6r
by 07stuntin6r
Alright guys I just got my crank arms today and I'm trying to find the BB that I need for them. Trying to wrap this up tomorrow!Image
by Nefarious86
2x 6806 bearings and 2 c clips
Using Tapatalk
07stuntin6r
by 07stuntin6r
Nefarious86 wrote:2x 6806 bearings and 2 c clips
Yeah just found it....just debating if u want to buy the tools and do it or have the shop.
PaulH
by PaulH
I want to fit those cranks is there an external bottom bracket I can use ?
07stuntin6r
by 07stuntin6r
PaulH wrote:I want to fit those cranks is there an external bottom bracket I can use ?
I just used a BB30, Got the old one out with a hammer and screwdriver. Just pressed mine in with a rubber mallet and a socket. Messed up around the frame a little but saved me 70 on tools. ImageImage
silvalis
by silvalis
07stuntin6r wrote:
Fri Oct 19, 2018 12:40 am
That sounds like a great way to damage your bb shell
Chasse patate
07stuntin6r
by 07stuntin6r
How so? I've worked on cars and used this method for bearings before. The socket for bearing and was smaller in diameter of the shell.
silvalis
by silvalis
07stuntin6r wrote:
Fri Oct 19, 2018 1:29 am
This isn't a steel car, it's a much softer aluminium bb30 shell with much tighter tolerances and in a relatively high stress area that is subject to lateral loading. Assuming you didn't damage the bearing after whacking it with a rubber mallet and a metal socket, there's no guarantee that you didnt put the bearing in properly straight and slightly ovalise the bb shell. There's a reason why BB presses are presses with guide rods and not hammer in jobs.
You'll find out if it went in properly or not after a few hundred km - if it starts to creak.
Chasse patate
07stuntin6r
by 07stuntin6r
I'm sure it will be fine, it has rings that are inside if those are flush with bearing then it more than likely in flush and straight.
IrrelevantD
by IrrelevantD
07stuntin6r wrote:
Fri Oct 19, 2018 2:02 am
The point he's trying to make is that the aluminum shell is relatively soft and using a hammer to bang a steel bearing into an aluminum shell could very well damage the shell in a way that isn't going to be immediately visibly apparent without careful inspection.
The better cheap DIY way would have been to get a threaded rod, some large, thick washers, and some bolts and make a cheap press. That way there's much less risk of damage due to blunt force trauma.
TLN
by TLN
Thinking of parting out my Allez Sprint X1 Limited in 61cm. If anyone is looking for full Sram Force groupset or 61cm frameset - DM me.
