201X Allez Sprint
WheelNut
by WheelNut
Ltyarbro42 wrote:
Thu Sep 20, 2018 5:31 pm
Just out of curiosity, how tall are you? Seems kinda odd that you'd have to slam the seatpost on a 56 sprint but not on a 54 CAAD12 as the CAAD actually has a longer seat tube and a higher standover due to the more horizontal top tube. On paper, the 56 Sprint is less than 1cm longer top tube and reach than the CAAD, so I would have thought the same as you, size up on frame size down on stem, specially if you're running a 130 already.
I am 5'10"ish with a 32" inseam and yeah I thought the same. My seatpost on the CAAD wasn't showing a lot but it has a longer seattube. Idk I may just be a weird size. Reach on the Sprint feels a little short with the 100mm stem. As I said, I don't have a lot of flexibility so the 170 crank may help in terms of both.
The seat tube on the Allez is shorter than the seat tube on the Cannondale by 5cm according to the geo charts. Not sure how it could be possible that you have less seat post above the ST collar on the Allez than on the Cannondale given the same BB to saddle top dimension. Are the geometry charts wrong perhaps (ormaybe I'm reading them wrong)? Or is one of your bikes not the size you think it is?
CAAD12 Size 54- ST length 570mm
Allez Size 56- ST length 520mm
Ltyarbro42
by Ltyarbro42
Oh, no no it's not shorter than the caad. Never said that. Just that it is very nearly slammed. Nothing wrong there, just that it looks a little funny.
07stuntin6r
by 07stuntin6r
taodemon wrote:That saddle would look great on my SL6. The $120 up charge for the colors is a bit rough when I already have an sworks power on it.
Where you find that at? I only see the new blue color on Specialized site
Sent from my SM-N950U using Tapatalk
Nvm
jfranci3
by jfranci3
Supacaz’s site has them
MayhemSWE
by MayhemSWE
07stuntin6r wrote:
Thu Sep 20, 2018 8:11 pm
https://supacaz.com/product/supacaz-swo ... er-saddle/
IrrelevantD
by IrrelevantD
Jclarke89 wrote:
Thu Sep 20, 2018 3:16 pm
I’m 6,1 and have to 56’s sprints, both have 130mm stems and the fit is perfect with the seat notched at 3.5.
A caad12 would not be smaller in regards to slamming the seat post on the sprint.
That's just really odd to me. Both of you are taller than me (5'9-1/2") and I have no problem with the 56 Allez Sprint. I have 172.5mm cranks, 100mm stem, slammed with a 7º rise and it feels about perfect and the seat post isn't slammed. Hope I'm not coming off as being confrontational, I'm not trying to be, it just sounds odd to me and I'm trying to wrap my head arround it.
Ltyarbro42
by Ltyarbro42
I just realized how this may be misunderstood. For anyone finding this in a search for future reference lol. When I say bottomed out, I do not mean my seat is on the seatpost collar. I mean the uncut seatpost is almost at its lowest point of insertion into the frame. If cut, it could definitely go several inches lower.
To answer you though, I might just have weird proportions and not have realized. After fiddling with it a little more, I'm pretty sure this will be a fine setup.
morganb
by morganb
I had to cut the seatpost on my Sprint, both when I had a 52 and when I sized up to a 54. On the 52 I had a high saddle height for that size and still bottomed out the post.
tonytourist
by tonytourist
I'm 5'11 and had a 54 Allez, I don't get why someone shorter than me would want a bigger bike?
morganb
by morganb
tonytourist wrote:
Fri Sep 21, 2018 2:02 pm
Different proportions or a need for a higher stack height? The seat angles are the same and the reach is similar so it would allow a less aggressive fit.
Ltyarbro42
by Ltyarbro42
morganb wrote:
Fri Sep 21, 2018 2:42 pm
Yeah, I went really low on my CAAD and I wanted to try Long and sorta Low instead of super Low.
Ltyarbro42
by Ltyarbro42
This is my first Specialized so I haven't had to deal with OSBB a lot. Can anyone explain wtf this bottom bracket's dimensions are? I'm removing the praxis to get something to fit my Rotor 3d+ power meter and I can't figure out what I actually need.
On a side note, *f##k* praxis for a 30 to 28 mm taper crank system, and why tf would Specialized throw something on there that keeps you from using their own branded cranks?
morganb
by morganb
Ltyarbro42 wrote:
Fri Sep 21, 2018 5:24 pm
OSBB except on a few early bike just means BB30.
WheelNut
by WheelNut
This is a great chart for referencing BBs: https://wheelsmfg.com/bb-standards
IrrelevantD
by IrrelevantD
Ltyarbro42 wrote:
Fri Sep 21, 2018 1:01 pm
Ok, that makes more sense.
As to Tonytourist's comment about why anyone shorter than him would want something bigger than a 54... I'm just under 5'10 and I've been on a 56 for about 28 years. I did have a Giant medium that translated to something closer to a small 55, but the 54 Allez Sprint felt too short in both length and height. I would have ended up with a 120mm stem and like 20mm in spacers and I didn't want to go either route. I've been professionally fitted and 56 really is the sweet spot for me.
