201x Specialized Allez Sprint DSW and Gen2
I also have both and do wonder how you experience them both. For me it's a little early to compare - only 300km on the SL7 - so I'll first ride it a bit more.
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
I suppose I refer more to how it fits. I find it almost as comfortable as the SL7 (I'm 50 next year, comfort is everything!) but also it's a smooth ride mind it's clearly slower than an SL7 but I think a lot of the SL7 speed comes from the Roval Rapides, simply the best wheelset I've ever ridden
Yep, not an issue.
IG: RhinosWorkshop
IG: RhinosWorkshop
Yes, the white powder you did find is corrosion. Clean up the dust and use some corrosion resistant carbon paste, I use Morganblue carbon paste in mine, but I think any other carbon paste should work. Just check the seatpost regularly, carbon doesn´t like aluminium at all
