201x Specialized Allez Sprint DSW and Gen2
Has Tour Magazin tested the new allez sprint?
Sorry for my english
Thought I'd chip in my build and weight
Allez Sprint 2022 Size 54 Water Effect Colour Way
Ultegra DI2 12s
Sigeyi Direct Mount Derailuer Hanger
52/36 Front Chainring
11/30 Casette
Roval Rapide Handlebar 40cm (Supacaz Bartape)
S-works Tarmac SL7 Stem - 110mm (Completely slammed and cut)
Shimano 105 SPD-SL Pedals
2x Normal Bontrager Cages (From previous bike)
JRC Components Wahoo Computer Mount with Bontrager Ion Front light mount below
Bontrager Ion 200 Rear Mounted on Seatpost
S-works Power Saddle (143mm Non mirror)
ENVE SES 5.6 - GP5000s TR 25mm tubeless setup
Total weight 8.4kg
4iiii left arm powermeter on the way but weight of that is negliable
Probably Darimo seatpost in the near future to further shave some weight
Ultegra DI2 12s
11/30 Casette
Total weight 8.4kg
If the price don't go up i don't buy
it isn't a super bike otherwise good damn it
For those that built up their 2022 Allez Sprint with Di2, did the frameset come with all the necessary Di2 grommets for your build? Mine only came with the rubber grommets, to plug the Di2 holes for a Sram Axis build.
It's the Di2 grommets for the front and rear derailleurs (part #s S159900006 and S209900054) that I'm missing. Will reach out to my LBS to see if they have these for my upcoming build.
Thanks.
Thanks.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
I had to respond to this. I'm bulding up my 22' Frame now. More then half of the small parts that are listed in the assembly manual as in the box(not the generic owners manual) are NOT in the box! I reached out to my LBS where I purchased the frame from. I listed all the part #'s and they contacted Specialized imediately. Specialized to my suprise had very few of the parts. And sent what they could. But basically told me "good luck" buying the rest! I have looked everywhere on line but sold out everywhere.Vuong05 wrote: ↑Wed Oct 05, 2022 9:33 pmFor those that built up their 2022 Allez Sprint with Di2, did the frameset come with all the necessary Di2 grommets for your build? Mine only came with the rubber grommets, to plug the Di2 holes for a Sram Axis build.
Thanks.
Similar to you I'm missing ALL the Di2 hardware. Including the seat post juntion box plate!
Not a good look by the big S! I have an S-works Tarmac, Crux E5. And was looking into a Diverge. NOT NOW! To ship an incomplete product is ridiculous. I'm hearing more and more of this with the Allez Sprint frames. Basically they did not have all the parts and said "screw them ship it anyway". They got my money. I waited 5 months for an incomplete frame.
Yeah, thought so too. The front grommet for the Di2 cable port, might work with any generic Shimano Di2 cable grommet. The rear port is tiny, and might need a special grommet from Specialized.... which they don't have in stock.Jrsq270 wrote: ↑Thu Oct 06, 2022 4:02 amI had to respond to this. I'm bulding up my 22' Frame now. More then half of the small parts that are listed in the assembly manual as in the box(not the generic owners manual) are NOT in the box! I reached out to my LBS where I purchased the frame from. I listed all the part #'s and they contacted Specialized imediately. Specialized to my suprise had very few of the parts. And sent what they could. But basically told me "good luck" buying the rest! I have looked everywhere on line but sold out everywhere.Vuong05 wrote: ↑Wed Oct 05, 2022 9:33 pmFor those that built up their 2022 Allez Sprint with Di2, did the frameset come with all the necessary Di2 grommets for your build? Mine only came with the rubber grommets, to plug the Di2 holes for a Sram Axis build.
Thanks.
Did someone found Specialized part number of the ''REAR DERAILLEUR GROMMET DI2'' for Allez Sprint 2022?Vuong05 wrote: ↑Thu Oct 06, 2022 6:16 pmYeah, thought so too. The front grommet for the Di2 cable port, might work with any generic Shimano Di2 cable grommet. The rear port is tiny, and might need a special grommet from Specialized.... which they don't have in stock.Jrsq270 wrote: ↑Thu Oct 06, 2022 4:02 amI had to respond to this. I'm bulding up my 22' Frame now. More then half of the small parts that are listed in the assembly manual as in the box(not the generic owners manual) are NOT in the box! I reached out to my LBS where I purchased the frame from. I listed all the part #'s and they contacted Specialized imediately. Specialized to my suprise had very few of the parts. And sent what they could. But basically told me "good luck" buying the rest! I have looked everywhere on line but sold out everywhere.Vuong05 wrote: ↑Wed Oct 05, 2022 9:33 pmFor those that built up their 2022 Allez Sprint with Di2, did the frameset come with all the necessary Di2 grommets for your build? Mine only came with the rubber grommets, to plug the Di2 holes for a Sram Axis build.
Thanks.
In the manual it's ''S159900006'' which is not the right one...
thanks
Hmm, I just purchased an Allez Sprint frame, so I'm curious what 'jackpot' I'll end up with in the small parts box.
However, when I built up a Diverge frameset about a year ago it was missing some of the small parts (not on Specialized). I had luck calling/walking into local bike stores and asking if they had any laying around that I could buy or have. I was able to pick up most of what I needed. I also purchased a few things from AMain Cycling who seem to stock various small parts for Specialized.
Ok, now I'm confused. If S159900006 is not the right grommet for the rear deraileur, then what is the actual part # for the correct part?JT508 wrote: ↑Fri Oct 07, 2022 12:18 amDid someone found Specialized part number of the ''REAR DERAILLEUR GROMMET DI2'' for Allez Sprint 2022?Vuong05 wrote: ↑Thu Oct 06, 2022 6:16 pmYeah, thought so too. The front grommet for the Di2 cable port, might work with any generic Shimano Di2 cable grommet. The rear port is tiny, and might need a special grommet from Specialized.... which they don't have in stock.Jrsq270 wrote: ↑Thu Oct 06, 2022 4:02 amI had to respond to this. I'm bulding up my 22' Frame now. More then half of the small parts that are listed in the assembly manual as in the box(not the generic owners manual) are NOT in the box! I reached out to my LBS where I purchased the frame from. I listed all the part #'s and they contacted Specialized imediately. Specialized to my suprise had very few of the parts. And sent what they could. But basically told me "good luck" buying the rest! I have looked everywhere on line but sold out everywhere.Vuong05 wrote: ↑Wed Oct 05, 2022 9:33 pmFor those that built up their 2022 Allez Sprint with Di2, did the frameset come with all the necessary Di2 grommets for your build? Mine only came with the rubber grommets, to plug the Di2 holes for a Sram Axis build.
Thanks.
thanks
Allez Sprint 2022 frame hole is alot smaller than Venge or SL7 one.. someone is a LBS found it?Vuong05 wrote: ↑Fri Oct 07, 2022 8:52 amOk, now I'm confused. If S159900006 is not the right grommet for the rear deraileur, then what is the actual part # for the correct part?JT508 wrote: ↑Fri Oct 07, 2022 12:18 amDid someone found Specialized part number of the ''REAR DERAILLEUR GROMMET DI2'' for Allez Sprint 2022?Vuong05 wrote: ↑Thu Oct 06, 2022 6:16 pmYeah, thought so too. The front grommet for the Di2 cable port, might work with any generic Shimano Di2 cable grommet. The rear port is tiny, and might need a special grommet from Specialized.... which they don't have in stock.Jrsq270 wrote: ↑Thu Oct 06, 2022 4:02 am
thanks
Thank you
Yes it does. If you want complete "hidden cables" you will need to have a headset cover custom 3d printed. I think the file was shared a few pages ago. You will also need to purchase the spacer kit. AND, AND our buddies at Specialized DO NOT include the small "Stem Bat" which screws into the bottom of the stem when you purchase the stem!
And in our new episode in Specialized Build Parts Roulette. The DI2 battery seatpost installation grommets are not there! Again sold out world wide!
"BUT WAIT THERE'S MORE!!!!" when you purchase the SL7 stem and the bar bat seperate AND the headset spacer kit......NOW not included is the HEADSET CAP! Guess what??????? You get to purchase that seperately!!! GEEEEEEE The Fun!
Also the grommet for the rear derailer Di2 that they have listed.....Once you buy it.....Suprise it is to big!!!! YEAH
