201x Specialized Allez Sprint DSW and Gen2
Quick Question Peeps
My 22' Frame came in yesterday. I'm slowly aquiring parts for the build. I have never built or owned a bike with Disc brakes. Can I run a 140mm rotor front and back to save weight? Would I need an adapter of some sort?
I have an Ultegra 8070 Group going on it.
Thanks
Thanks
What spacer/preload order did you use for your crank?
I'm using that same BBinfinite BB and I'm not sure I've got the chainline exactly where it needs to be.
ancker wrote:What spacer/preload order did you use for your crank?
Your bike looks incredible. The paint scheme is lovely
The colorway should be Sand-White Mountains/Satin Red-Gold Pearl and it is at least available in Germany:
https://www.specialized.com/de/en/allez ... 028-189820
Thanks. I wasn't sure about it when it ordered it, but loved it once I got it out of the box.nulldreiundreissig wrote: ↑Tue Jul 12, 2022 10:55 amYour bike looks incredible. The paint scheme is lovely
I loved it even more after I built it up and got it out in the sunlight.
Yep you can and you won't need to use an adaptor. However, I'd only personally do it if you're light and live somewhere fairly flat.Jrsq270 wrote: ↑Thu Jul 07, 2022 8:35 pmQuick Question Peeps
Thanks
This is rad. What's the final weight?Snwbrdr3448 wrote: ↑Fri Jul 15, 2022 8:20 pmStill need the 3D printed part... but this is the build. Rides great.
Red AXS 1x 48 / 10-33
AbsoluteBlack Hollowcage
Princeton Carbonworks 7580s
I'll need to re-weigh it next week to confirm when I have access to a scale again, but I believe it was 18.5 pounds when I weighed it earlier this week. It's basically the same weight as built here as my SW Venge - note that the Venge has the aerobars on with TT di2 shifters, and clx64s.rhender wrote: ↑Fri Jul 15, 2022 9:00 pmThis is rad. What's the final weight?Snwbrdr3448 wrote: ↑Fri Jul 15, 2022 8:20 pmStill need the 3D printed part... but this is the build. Rides great.
Does anyone in Europe have an older Allez Sprint frame they would sell?
