201x Specialized Allez Sprint DSW and Gen2
LanceLegstrong
by LanceLegstrong
CoastTheMost wrote:
Thu Mar 16, 2023 11:45 pm
LanceLegstrong wrote:
Fri Mar 10, 2023 3:03 pm
Has anybody seen an Allez/Venge stem top cap?
Performance Bicycle website
Are you sure? I don't see anything on there. To clarify, I'm looking for this, but for the Venge stem.
https://www.racewaredirect.co/shop/spec ... nt-spacer/
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
CoastTheMost
by CoastTheMost
Fri Mar 17, 2023 12:12 am
Sorry, I misunderstood what you were looking for. I'm not very familiar with the Venge stem but with the amount of custom 3d printed designs on that site, you might ask them if they would do a comission to create what you are looking for.
SamTCC
by SamTCC
Does anyone have experience running a mechical gear / hydraulic brake setup with the 3D printed SL7 cap on the new Allez sprint? Hoping to use it on mine with the SL7 stem but not sure 4 cables will fit.
Vuong05
by Vuong05
SamTCC wrote:
Tue Mar 21, 2023 3:06 pm
My local shop had to build one up last year with Ultegra 11spd mechanical, and it was a huge pain in the ass to run 4 cables through the 3D printed SL7 cap. It can be done, but not something you want to do often. It was a 52cm frameset, so a larger frameset with longer stem might be easier. When he built up my 2022 Allez with 3D printed SL cap and Shimano 12spd Di2, it was a night and day difference.
Cheers.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
SamTCC
by SamTCC
Vuong05 wrote:
Tue Mar 21, 2023 4:01 pm
Cheers.
Thanks for response. It's already cabled, so hoping they can just reverse the outer cables in towards the handlebars... 56cm frame with 140mm stem, so plenty of space there!
Although unsure if outer cables go through the entire frame :noidea:
WWerreWW
by WWerreWW
I did it this weekend, my starting point was the standard 105-equiped comp model. Fitting the cables through the 3D printed portion was annoying, I had to modify the print by removing a bit of material to make space. Other than that, the toughest part for me was working with the existing cables/hoses. I didn't want to replace cables/hoses (because I'm cheap), so working with the lengths that I had was tricky. I had to cut the ends of the hydraulic hoses in order to remove the nuts/barbs/olives and allow them to pass through the holes on the stock headset cap, but that reduction in length made everything VERY tight on re-assembly. The whole thing was so tight that the Tarmac spacers don't seem to want to line up quite perfectly, but I'm fairly happy with the result for the moment.
SamTCC
by SamTCC
WWerreWW wrote:
Tue Mar 21, 2023 10:28 pm
I did it this weekend, my starting point was the standard 105-equiped comp model. Fitting the cables through the 3D printed portion was annoying, I had to modify the print by removing a bit of material to make space. Other than that, the toughest part for me was working with the existing cables/hoses. I didn't want to replace cables/hoses (because I'm cheap), so working with the lengths that I had was tricky. I had to cut the ends of the hydraulic hoses in order to remove the nuts/barbs/olives and allow them to pass through the holes on the stock headset cap, but that reduction in length made everything VERY tight on re-assembly. The whole thing was so tight that the Tarmac spacers don't seem to want to line up quite perfectly, but I'm fairly happy with the result for the moment. PXL_20230320_065544839.jpg
Good to see. I've booked mine in with a mechanic on Friday next week. Will post pictures once done. Fingers crossed they're happy with the faff :P
JaeOne3345
by JaeOne3345
In the future you can use a dremel type rotary tool to cut the olive length wise 2-3 times, and simply replace it with a new one without cutting the lines. You can also leave the barb in place and reuse it with this method.
WWerreWW
by WWerreWW
JaeOne3345 wrote:
Wed Mar 22, 2023 8:50 pm
That's a great tip, thank you! It was my first time messing with hydraulic lines, so I wasn't quite brave enough to try something like that.
JaeOne3345
by JaeOne3345
WWerreWW wrote:
Thu Mar 23, 2023 1:13 am
No problem! Takes a steady hand but it's fairly easy. The finer the cutting attachment the better. Don't forget the eyepro.
SamTCC
by SamTCC
The mechanic found it too tight so stuck with standard cover :(
WWerreWW
by WWerreWW
SamTCC wrote:
Fri Apr 07, 2023 8:18 pm
That may be becuase you have yours totally slammed, mine has a few spacers which seems to help. Ah well, at least you got the cooler colour!
joesch
by joesch
Oh, very nice setup!
Quick question: is this a Tarmac SL7 stem / Roval Rapide handlebar combo?
AnonymousRacer
by AnonymousRacer
Allez Sprint, Project 74 Team Edition paint job:
(hopefully image works...)
formerly known as airsoft510
2022 Specialized Allez Sprint 12spd Ultegra, 8.4kg
2016 CAAD 12 11spd Ultegra, 7.62kg
2009 CAAD 9 10spd Sram Red, 6.72kg
GaBa
by GaBa
Will this be available to the public?
