Nice sled!! Super clean. Toolbox and work space very nice as well You did good, real good.Vuong05 wrote:Just finished my new Allez Sprint.
Size 49, in the water effect colorway. Not light at 7.85kg, but rides sublime with this setup.
201x Specialized Allez Sprint DSW and Gen2
Thanks Ymerej, but I can't take credit for the space or toolbox. That belongs to my good friend who finished the build for me. Took awhile to hunt down all the parts needed for the build, especially the handlebars and small Di2 grommets. Now if only the weather here would offer a small window of sunshine to ride outdoors.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
Hi brentvelo,
I got the head set adpater off Ebay. Much better quality than what I was able to print locally. He sells a ton of them, and they are very high quality. Send me a PM, and I can send you the Ebay link.
Cheers.
Looks very nice & timeless. Has an "aero-titanium-bike-vibe".
Vuong05 wrote: ↑Mon Oct 31, 2022 6:18 pmHi brentvelo,
Cheers.
Could you post the ebay link? Or the seller name?Vuong05 wrote: ↑Mon Oct 31, 2022 6:18 pmHi brentvelo,
Cheers.
PM sent.DiamondInc wrote: ↑Thu Dec 01, 2022 2:22 pmCould you post the ebay link? Or the seller name?Vuong05 wrote: ↑Mon Oct 31, 2022 6:18 pmHi brentvelo,
Cheers.
Cheers.
Got my 2022 Allez Sprint built up. Including the recommended ebay adapter for the SL7 cockpit integration. Only ridden the bike twice so far and both times the headset had a small amount of play when I got home. Maybe the spacers, bearings and all just settled a little. Maybe I wasn't tightening the cap enough. I retightened the cap quite a bit more and torqued the stem bolts to 5nm. Hopefully it was user error and won't be a big deal. Anyone else have any issues with this that I should be aware of?
A special headset shim on top, e. g. from Cane Creek?brentvelo wrote: ↑Mon Dec 05, 2022 6:48 amGot my 2022 Allez Sprint built up. Including the recommended ebay adapter for the SL7 cockpit integration. Only ridden the bike twice so far and both times the headset had a small amount of play when I got home. Maybe the spacers, bearings and all just settled a little. Maybe I wasn't tightening the cap enough. I retightened the cap quite a bit more and torqued the stem bolts to 5nm. Hopefully it was user error and won't be a big deal. Anyone else have any issues with this that I should be aware of?
